Emblempros
Old 06-27-2009, 08:29 PM   #1
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
Exclamation Urgent - How to drain/fill rear-end fluid
Okay - now don't take me for being dumb, I have changed many rear-end fluids on trucks before, easy, bottom plug drain, top plug fill. Problem is, this rear end doesn't look anything like them and there are so many bolts in various locations I am not sure which is the drain and which is the fill, please help - I am trying to get this done before going on a cruise with a bunch of friends tonight.
Thanks!
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
RickyTheStorm is offline   Reply With Quote
Old 06-27-2009, 08:31 PM   #2
AGM76
Drives: 1995 z28 - 2000 SS - 08' vette
Are you swapping the fluid? Like with a red line fluid?
AGM76 is offline   Reply With Quote
Old 06-27-2009, 08:33 PM   #3
RickyTheStorm
I am changing out the current fluid with Mobil 1 75W-90 as recommended by the manual at 1500 miles if planning on racing the car. So I just need to drain the existing fluid then put the new fluid in.
Old 06-27-2009, 08:43 PM   #4
buster6070
buster6070's Avatar
Drives: 02 Camaro, 10 2SS, 07 VTX1300
Hmm, I didn't notice that in the manual. Good to know. Make sure I'll get that done with my first oil change.
buster6070 is offline   Reply With Quote
Old 06-27-2009, 08:45 PM   #5
RickyTheStorm
Yea, it is under the "break-in" section
Old 06-27-2009, 09:42 PM   #6
Restroom
Screw it; buying a Vette
Restroom's Avatar
Drives: '08 Corvette C6 Coupe (A6)
Thumbs up
Originally Posted by RickyTheStorm View Post
as recommended by the manual ... if planning on racing the car.
Wow, that's cool. I wonder how they define "racing", and whether if you do in fact track the car and something blows up, they'll still fix it as long as you did what the manual told you to do.
Restroom is offline   Reply With Quote
Old 06-28-2009, 08:38 AM   #7
RickyTheStorm
I was apparently blind - two plugs are located on passenger side. They use a 3/8" socket. Amazingly they are magnetic plugs, had some shavings on them but not much - all is changed and ready to go
Old 06-28-2009, 07:35 PM   #8
gtrpryde
gtrpryde's Avatar
Drives: 03 Evo 8, 93 KAT S13
The manual says you need to use GM fluid (new criteria) with LSD additive...
Did you check into that? Just a heads up
gtrpryde is offline   Reply With Quote
Old 06-28-2009, 09:29 PM   #9
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
Kind of off topic, but does the manual say anything about flushing out the rear end for just normal use?
UCI CamaroFan is offline   Reply With Quote
Old 06-28-2009, 09:49 PM   #10
Vash
Drives: 00 Blazer
You don't flush gearboxes unless your rebuilding. Just change fluid as scheduled.
Old 06-28-2009, 09:57 PM   #11
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I'm pretty sure that is what he meant. He just wanted to know for normal use should you change the fluid.
Old 06-28-2009, 09:59 PM   #12
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
so, what you guys think is the best gear oil? Royal Purple, Amsoil, Mobil 1, Red line, or get the stock stuff with the additive?
Also whats the recommended weight?
gotpball44 is offline   Reply With Quote
Old 06-28-2009, 11:13 PM   #13
RickyTheStorm
I am pretty sure Mobil 1 is acceptable - this is directly off of the label on the back:
Originally Posted by Mobil 1 Label
Mobil 1 Synthetic Gear Lubricant LS is a race proven fully synthetic product that outperforms conventional, extreme-pressure type gear lubricants in both conventional and limited slip applications and helps provide:
- Outstanding protection of hybrid differentials where an API GL-5 quality 75W-90 oil is recommended
- Minimal wear and spalling under high-speed, high-torque and high-horsepower conditions.
- Exceptional resistance to oil breakdown from heat and extended high-speed operation.
- Outstanding cold temperature performance.
- Gear shifting ease and reduction of chatter.
- Excellent durability for towing and heavy loads.
- Less friction which helps to lower operating temperatures.
Mobil 1 Synthetic Gear Lubricant LS 75W-90 exceeds the performance requirements of API Service GL-5.
I did however send Mobil 1 an e-mail asking to verify, we will see what they say.
Old 06-28-2009, 11:14 PM   #14
RickyTheStorm
I go Mobil 1 for everything, recommended weight is 75W-90
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
Mystery fluid 96CAMaro 4th Generation Camaros 6 07-30-2008 07:03 AM
1985 Z-28 (Not IROC) Rear End aga6943 3rd Generation Camaros 3 04-22-2008 05:16 PM
Rear end ratios chevys Wheels and Tires Talk Sponsored by The Tire Rack 15 03-22-2008 11:47 PM
Preproduction Rear Photo Indicates Complete Redesign? sbg 5th Gen Camaro SS LS LT General Discussions 42 01-17-2008 04:09 PM
