Old 05-22-2013, 12:31 PM   #1
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
Have my new engine..wait to add mods?
Should I wait to add my longtubes, manifold spacer, cold air intake, and HF cats 2.5 inch exhaust with resonated xpipe and muffler delete? Not sure if I should wait a couple thousand miles or so
Sent from my DROID RAZR HD using Tapatalk 2
CamaroC-17 is offline   Reply With Quote
Old 05-22-2013, 12:46 PM   #2
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Hate to say it, but given your history I would wait a bit to make sure it doesn't have to go back in for more service.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 05-22-2013, 01:24 PM   #3
KMPrenger
KMPrenger's Avatar
Agree, and then when you add them you may not want to do all of it at once either.
Old 05-22-2013, 01:27 PM   #4
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Why is that?
Old 05-22-2013, 01:30 PM   #5
KMPrenger
KMPrenger's Avatar
Originally Posted by CamaroC-17 View Post
Why is that?
Well it probably doesn't matter. Just thinking if an issue pops up that can be difficult to diagnose, like a noise, or an issue with engine performance or smoothness...it could be a little more difficult to pin point the problem.
I dunno...don't listen to me! lol
Old 05-22-2013, 03:53 PM   #6
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Well with my problems aside, is there a mechanical reason to wait? Like does the engine need broken in first?
Old 05-22-2013, 04:08 PM   #7
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
No real mechanical reasons IMHO....but if I was you I would follow Gretchen's and KM's suggestions.
Blade is offline   Reply With Quote
Old 05-22-2013, 04:20 PM   #8
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Well fine then...I'll wait
I was thinking about just putting on the intake and mace IM spacer since they are easy to take off. Then later doing the rest of my exhaust and tune. In the mean time I may re-polish (wet sand first this time) my IM and paint the plenum cover to match my valve covers.
Old 05-22-2013, 04:40 PM   #9
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I would give the engine at least 1500 miles to break in. That's the recommended break in time. After that, it's all up to you
Old 05-22-2013, 04:52 PM   #10
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
So what is the proper break in method?
Old 05-22-2013, 04:56 PM   #11
lscamaro
lscamaro's Avatar
That's a topic of much debate. Many, including the owner's manual, say to take it easy the first 1500 miles and then you're good. Others say beat on it for the first 1500, change the oil, and then drive like normal. I personally beat on mine from the very beginning
Old 05-22-2013, 07:01 PM   #12
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
I've broken in many motors using this procedure including the LLT.
You'll need to find a road wit little or no traffic. Stay in second gear and accelerate at about half throttle from 30mph to 55/60 mph. When you reach 55/60, slowly reduce speed to 30mph. Repeat the process 4 times.
The purpose of the controlled speed increase / decrease is to build pressure on increase and build back pressure on the rings on speed decrease. The proper seating of he rings will affect several things, most importantly how efficiently the rings are seated to the cylinder walls. There's a difference between running hard and flogging a motor.
Take a look in the first few pages of the mace cam install thread where tracy posted about no oil in the intake manifold - at almost 18k miles I had no oil in the intake manifold. I didn't add a Catch can until almost 11k miles.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 05-24-2013, 11:34 AM   #13
TooCool5
TooCool5's Avatar
Did something similar with mine only I took it on Rt 9 in CT up and down the mountains at highway speed.
No oil in my intake either.
