Emblempros
Old 05-22-2013, 01:30 PM   #1
NYJets77
Drives: 2013 2LT/RS Summit White
Anyone else wish Tap Shift Mode could be disabled?
This is the 3rd time since I got my car that I've went to signal a leftward lane change, hit the paddle on the steering wheel instead of the turn signal, and downshifted into 1st while on the parkway.
Besides the stress on the car, I'm now in a lane blocking traffic.
The sucky part is that it can be initiated in D, instead of having to be in M.
NYJets77 is offline   Reply With Quote
Old 05-22-2013, 01:40 PM   #2
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
mine doesnt change when i tap them in D....?
i didnt know the paddles were active when not in M, i've pushed them while driving and d, and nothing happens...
13blackLS is offline   Reply With Quote
Old 05-22-2013, 01:45 PM   #3
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
Only does this on the V6 models. With V8 models, you have to be in M mode.
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 05-22-2013, 01:46 PM   #4
dave eckhardt
dave eckhardt seabees
Drives: 2012 camaro 2 LT convertible
tap shift delete
I wouldn't delete the tap shift.I would get a carter shifter.problem solved.you can delete /disable the paddle shifters.look up thread on how to install carter shifter.
dave eckhardt is offline   Reply With Quote
Old 05-22-2013, 01:49 PM   #5
jewel25
Aug 18, 2017
jewel25's Avatar
Drives: 2011 RJT 2LT/RS
Nope, I tap mine all the time and I don't shift. Only works when in Manual mode.
jewel25 is offline   Reply With Quote
Old 05-22-2013, 02:06 PM   #6
Yazeed
Drives: Camaro 2LT / RS
No, i have a V6 and the gear must be on M mode to use the tapshfts
TEAM LLT !!
MRT V2.0
CAI
Yazeed is offline   Reply With Quote
Old 05-22-2013, 02:14 PM   #7
Mr pogo
Drives: 96 Imp SS, 13 Camaro 2SS AGM
if this is really a problem you can always install an on/off switch at the signal wire in the steering column.
I put in CFD's pistol grip shifter and installed a micro switch under the dash that switches manual operation from the paddle to the shifter whenever I want.
it would not be difficult to just wire in a switch to just turn off the paddles, see CFD's pistol grip shifter thread on which specific wire it is.
Mr pogo is offline   Reply With Quote
Old 05-22-2013, 02:19 PM   #8
40years
40years's Avatar
Back at the end of February, my SS was involved in an accident (not my fault) and was in the shop for 3 weeks. I was in a rented 2013 Camaro LT from Enterprise and was able to use tap shift all day long while the shifter was in "D". NEVER had to put it in "M" to tap shift.
Old 05-22-2013, 02:26 PM   #9
Jonster
Jonster's Avatar
Drives: '12 2ss IOM Camaro Vert
I have a 2012 automatic and the paddle shifters work in D.
Jonster is offline   Reply With Quote
Old 05-22-2013, 02:29 PM   #10
trw427ss @ Futral
trw427ss @ Futral's Avatar
Drives: 2013 2SS/RS L99
My 13 SS will tap shift in D!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss @ Futral is offline   Reply With Quote
Old 05-22-2013, 02:33 PM   #11
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
I have a 2SS/RS and I can tapshift in D.
DaFisch is offline   Reply With Quote
Old 05-22-2013, 02:50 PM   #12
dkp2LT
dkp2LT's Avatar
Drives: '10 2LT/RS, '13 GT/CS, '10 Flex
2010 2LT/RS. When in D I can tap all day long & nothing happens. Has to be in M.
dkp2LT is offline   Reply With Quote
Old 05-22-2013, 02:52 PM   #13
solteroblues
solteroblues's Avatar
Drives: 2011 Camaro LS IBM
My '11 V6 will not tap shift in D, only in M. maybe it's year or package specific?
solteroblues is offline   Reply With Quote
Old 05-22-2013, 02:52 PM   #14
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
X 2
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
