Old 05-22-2013, 09:33 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Seafoam treatment, Oil Change and Catch Can Installation
Wanting to double check with y'all that I am one the right track here with these procedures...
I plan on doing the seafoam treatment in my gas tank, oil, and intake manifold via this "how to"
http://www.ehow.com/way_5848602_sea-...treatment.html
Afterwards I will do my oil change and install my catch can to insure that I am preventing anymore oil from caking up on the valve train or throttle body.
Any objections or suggestions?
AAC Amber Halo's///LSR Short Throw Shifter///BMR Front & Rear Sway Bars///BMR Lowering Springs///Airaid CAI///BBK Headers & Mid-Pipes///Borla Exhaust///Martin Smallwood Custom Cam w/ Support Mods///Tick Performance Dyno Tune///Port&Polished LS3 Heads///Elite Engineering Catch Can///Gen5DIY Separate Clutch Reservoir///Harwood 5" Cowl Induction Hood
Cornflakes'Camaro is offline   Reply With Quote
Old 05-22-2013, 09:39 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
You shouldn't need to do the brake bolster part, but otherwise your good.
Click to view my build thread
Old 05-22-2013, 09:45 PM   #3
Cornflakes'Camaro
Ok then. How else would I get the oil off of the throttle body/intake and valve train though? I understand the combustion chamber will be cleaned from the foam in the gas, but as far as the top of the valves is what I am wondering...
Old 05-22-2013, 09:55 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You can do the brake booster with out a problem. I've done it many times on all my cars, you do half of a bottle on the gas tank the other in the crankcase and I've done a half bottle on the brake booster hose.
Old 05-22-2013, 10:04 PM   #5
The Stig
The Stig's Avatar
Well then yes you'd want to do the brake booster. I was just saying if the car is relatively new it shouldn't need it - but if you're wanting to clean out as much as possible, then yes you'd want to do that too.
Sorry my earlier post wasn't clear.
Old 05-22-2013, 10:12 PM   #6
Cornflakes'Camaro
No you're fine dude. I've seen your posts and write ups, and I've seen you know what you're talking about. The car is a 2011 w/ 31XXX miles on it. I routinely use fuel system cleaner and fuel injector cleaner. Also, is there any difference in catch cans and how they are made? Or is it the general idea/engineering that matters most?
Old 05-22-2013, 10:21 PM   #7
Cornflakes'Camaro
Awesome, Thank you for that.
Old 05-23-2013, 12:07 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What about the clean side vacuum line? It's right there on the intake tube, is before the TB, and very easily accessible.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-23-2013, 09:46 AM   #9
The Stig
The Stig's Avatar
The three top/best brands are RX, Elite Engineering, or Mike Norris. SC2150 has done a few great write ups on oil catch cans (I'll see if I can find them), explaining the difference between the three I mentioned and the cans you find on eBay for like $20.
And yea, if you have 31,xxx miles of not using a catch can I'd definitely recommend doing the full cleaning.
Possibly could work.
Old 05-23-2013, 05:36 PM   #10
Cornflakes'Camaro
I will certainly be doing a full cleaning, no doubt about it. I have checked ebay and Elite Engineering cans are going for roughly $150 bucks...did you mean to put a "1" in front of that "20"?
Old 05-23-2013, 06:02 PM   #11
The Stig
The Stig's Avatar
Ieant $20 for a generic eBay one. Not an elite engineering one.
Old 05-23-2013, 06:24 PM   #12
Cornflakes'Camaro
Yea I figured that. Just wanted to double check. I am purchasing an Elite Engineering Catch Can right now...
Old 05-24-2013, 10:54 AM   #13
TECADON
TECADON's Avatar
Drives: 2011 Camaro 1SS/RS
I have used Seafoam on many vehicles and for the Camaro I used the vacuum line that is behind the throttle body on left where the oil residue would be going into the manifold from the factory PCV setup and it worked fine, I did take the Throttle body of and clean it manually, after and the intake looked clean. I use 1/2 a can in tank and 1/2 in upper intake through the vacuum line i stated.
I am however against using it in the oil, I look at it this way if the oil is changed on a regular basis and using synthetic it should not be dirty inside, and if it is I don't want to break up the bad stuff and let it loose in the engine. But that's just me.
2011 SS/RS Homemade CAI, Doug Thorley Muffler Delete, Burns Stainless X-pipe and Dynomax Race Bullets, 8k HIDS and Fogs with harness, Tuned by Me on HPTuners
Yes its quick...quicker then you think!!!
TECADON is offline   Reply With Quote
Old 05-25-2013, 05:01 PM   #14
Cornflakes'Camaro
interesting point. what if I use it in the oil and then change the oil shortly after? that should remove most particles the are broken loose, if there were any to start with, like you stated
