BORLA
Old 05-22-2013, 11:46 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
cleaning the grille...
as you can see in my avatar i HAD a grille. it was on there when i bought the car and i just removed it. the black plastic in the grille is now rotten and probably never cleaned. u can see lines of dirt built up where the grille was. i tried scrubbing with a toothbrush endlessly with heavy duty glass cleaner, soap, bug & tar remover as well as mothers black plastic + trim shine. nothing really works. any suggestions other than getting it painted?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 05-23-2013, 01:09 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
I would suggest a good all purpose cleaner for instance Adams makes a great APC that eats away dirt and grime like no other. Should solve your problem
Lil' Nasty is offline   Reply With Quote
Old 05-23-2013, 01:16 AM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Got a picture?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
