HURST
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 05-29-2013, 07:44 AM   #15
newmoon
newmoon's Avatar
Drives: 2013 Boss 302 RR
Originally Posted by jkof08 View Post
ok, i have a 2010 2SS A6 with a Hennessey CAI, Diablo Tuner on the 93 octane tune and firm shifts, Flowmaster Pro Series Axel Back, and the 1LE strut Brace. Vs my friends stock 2013 1LE, who would win in the 1/4 mile?
My money is on your car.
2013 Boss Mustang - Present Toy
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 05-29-2013, 08:50 AM   #16
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
1LE if he can drive.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 05-29-2013, 09:19 AM   #17
jkof08
jkof08's Avatar
Drives: Black 2SS/RS
this is from windingroad.com The only powertrain difference between the 1LE and standard SS is the gear set used in the Tremec six-speed manual, which now features a shorter, crisper throw. A 3.91 rear end sits in place of the 3.45 found on the SS, which gave our tester a bit more pep off the line. Unless you drive the two back to back, it’s not an especially big standout, though. The 1LE pulls, but it doesn’t seem to have much more authority than a normal SS.
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM)
jkof08 is offline   Reply With Quote
Old 05-29-2013, 12:03 PM   #18
jkof08
jkof08's Avatar
so what if i put 3.91 gears on it?? like these http://www.lingenfelter.com/mm5/merc...gory_Code=C366
Old 05-29-2013, 12:13 PM   #19
Bad70supreme
1le is a high 12 car stock, quite a few 12.8s so far from what I have seen, a stock ss m6 is a high 12 car but takes a very good pass to get it done! No way your running 12s with 22s and no headers! He definitely has an advantage, one good launch and he's walking you. Put some long tubes and a dyno tune on your car and ditch the big wheels!
Old 05-29-2013, 12:13 PM   #20
newmoon
newmoon's Avatar
I don't think you need gears. You should have his car covered the way you sit. If you want to upgrade anything I would scrap the Diablo tune and go with a Jannetty tune and maybe some DRs, this will get you into the 12:40s range, add a set of LTs and you will be sitting at low 12s. Let us know how it turns out.
Old 05-30-2013, 11:53 PM   #21
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
The 1LE has stickier tires, stronger axles, stiffer suspension (so less wheel hop), lighter wheels and shorter gearing. These all help greatly when dig racing so I wouldn't even bother bench racing, considering the cars have several but completely different upgrades and different transmissions. Best way to find out is to just do it. But if he ran a 13.5 you should get him since you have an auto and he clearly needs to get a little better at driving.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 05-31-2013, 12:56 AM   #22
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Originally Posted by 2012-2SS View Post
I'd say the 1LE has the advantage because of his better rear gears.
Sent from my Galaxy S3
Slight disadvantage 1le has to shift into 4th to finish the 1/4.
However mention to your friend the launch control feature he has and its over. He should run high 12s all day long.
BigBlock69RS is offline   Reply With Quote
Old 05-31-2013, 01:07 AM   #23
Biscuitpie
Biscuitpie's Avatar
However mention to your friend the launch control feature he has and it over. He should run high 12s all day long.
Is launch control safe now? I never really followed up on that whole thing. I've used it a few times but I definitely won't be using it with my mods... It just seems like the RPMs (4500) are higher than necessary for a good launch.
Old 05-31-2013, 01:44 AM   #24
BigBlock69RS
Ed
Should keep him right at the edge of traction, not sure about power levels above stock.
Old 06-01-2013, 09:58 AM   #25
jkof08
jkof08's Avatar
Tack Time
so i didnt do as good as i hope but not bad for my first time. next time im going to launch on the last yellow instead of green.
Old 06-01-2013, 10:46 AM   #26
jph2275
jph2275's Avatar
Drives: 2010 Camaro 2SS/RS CGM
Originally Posted by Deki View Post
You're gonna run a 13.7@107
This guy ... He was close
Pat
2010 2SS/RS M6
Originally Posted by HDRDTD View Post
As long as it has enough horsepower, I don't really care if it's a 4, a 6, an 8, or a 10.
And I don't really car how they make the horsepower, whether it a Turbo, supercharged or just a whole lot of hamsters.
3.91's, TSP Longtubes, SWG Tune, Vararam, and a heavy foot
jph2275 is offline   Reply With Quote
Old 06-01-2013, 10:56 AM   #27
jkof08
jkof08's Avatar
ya if i get a better launch i will be low 13's. i need to get 20 inch rims if u no anyone who may want to buy mine PM me
Old 06-01-2013, 01:21 PM   #28
Jims Mongoose
Jim
Jims Mongoose's Avatar
Drives: 2013 Black 2SS 1LE
Hello to all, I'm fairly new with a 2LT RS 2013 camaro. Really looking to buy a 2014 2SS 1LE.
I need to know the jargon. What are 'DRs, and what are 'LTs'.
Thanks for your help.
Jim
Jims Mongoose is offline   Reply With Quote
