Old 05-23-2013, 08:20 PM   #1
catmancan
Drives: 2010 RS/SS
MAX Valve lift
What is the max valve lift on a cam you can install before interference with pistons on a stock LS3?
catmancan is offline   Reply With Quote
Old 05-23-2013, 08:30 PM   #2
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Depends on the design of the cam.Average are .610-.620 range.
But I have seen some push it to .650.
I'm sure the cam specialists will chime in here in a bit.
Motion427 is offline   Reply With Quote
Old 05-23-2013, 08:34 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
There's more to it than that, what's the Lsa? What's the durations? Lots more info is needed sir.
Old 05-23-2013, 09:14 PM   #4
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Yep, lift is probably one of the least things that affect piston to valve. Read the sticky at the top of the page.
Old 05-24-2013, 11:40 AM   #5
Jason 98 TA
Drives: Camaro
Your best bet is to talk with a experienced camshaft design shop. I can give you a cam with less than stock lift that will bend every valve on startup, or a .750" lift camshaft that would clear just fine. Really there are so many things that go into p/v that are way more important than max lift.
Give us a call if we can help you on it, we do more LS camshafts than anyone else in the world.
Jason 98 TA is offline   Reply With Quote
