Emblempros
Old 05-23-2013, 09:35 PM   #1
brettsimons
brettsimons's Avatar
Drives: 2011 Automatic Camaro 2SS
Cam Help in L99
Hey guys,
So I really want to do a cam and after talking to my brother and Joe at Powertech Performance, I was convinced that the best option for my scenario (don't have thousands of dollars to pay someone to replace lifters/remove afm) was to get one of the AFM/VVT cams from Texas Speed, Comp cams, or Mast. Now I basically just have these questions:
  1. Does anyone know how different the AFM 1, 2, and 3 cams are? Like how much more aggresive is 3 compared to 2 and 1?
  2. Does anyone know where to find any dyno numbers for each cam or what the general increase in HP and torque is? I looked everywhere and couldn't find anything and if I did, it was just the dreaded red x
  3. Do I need to replace the push rods? I figured I do but I just want to make sure...
  4. Lastly, do I need to replace the springs or anything else in the valve train?
As always I love this forum and thanks for the help
brettsimons is offline   Reply With Quote
Old 05-23-2013, 09:46 PM   #2
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
meshamey is offline   Reply With Quote
Old 05-23-2013, 09:51 PM   #3
SPCBA
Drives: pleather and Chiclets
vvt good afm bad. ditch the afm tune aaaannnnnddddd internals.
SPCBA is offline   Reply With Quote
Old 05-23-2013, 10:07 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Sorry but heads still need to come off bud. I wouldn't even bother doing a cam in an L99 unless it was a MAST SS cam or a vvt3 or wait for rhino79's cam coming out. And a matching TQ converter is a must.
Old 05-23-2013, 10:11 PM   #5
tys2010camaro
tys2010camaro's Avatar
Drives: 2010 camaro ss
Little nows what he's talking about!
He helped me big time on doing an LS3 conversion and cam and components. Saved me big$ and it ended up right!
tys2010camaro is offline   Reply With Quote
Old 05-23-2013, 10:11 PM   #6
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
You still have to replace 8 of the lifters along with all the valve train parts my build cost alil less than 5gs including l99 to ls3 conversion with a triple disk converter.
Nightmare2012 is offline   Reply With Quote
Old 05-23-2013, 10:17 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Thanks TY! So how's the car?
Old 05-23-2013, 10:19 PM   #8
flyer08
Drives: 2010 2SS/RS
I have vvt2 if you want to check it out.
Stay far away from arm cams and replace the arm lifters. Tsp is coming out with a vvt4 and if I was doing it now I'd go with that.
As far as replacing parts, you can get the kit from tsp that replaces most the stuff you mentioned and you will want to replace stuff. It's basically the ls3 conversion with most the parts you change out but still leaving vvt
flyer08 is offline   Reply With Quote
Old 05-23-2013, 11:54 PM   #9
brettsimons
Thanks for the help guys! I know AFM sucks :( but I at least have it tuned out! The only thing is I'm getting 3.91 differential gears installed next week and so it's setting me back a pretty penny since I can't do it myself with my brother. I looked at the DIY Cam install and that is something me and my brother can do pretty easily but replacing the lifters is supposed to be hard and there is not DIY guide that I've seen to help keep us on track :( I really wish I could replace the lifters but unless I can do it myself, the cost of labor is just too much. But a VVT Cam is definitely what I'm aiming for if I can convince my brother to help me replace the lifters
Anyone know of a good lifter replacement guide or AFM removal guide?
Old 05-24-2013, 01:36 AM   #10
Nightmare2012
come find out;)
The lifters come off fairly easily just take off the heads and walla there they are.
Old 05-24-2013, 06:12 AM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Originally Posted by brettsimons View Post
Hey guys,
    Yes 3 is the more aggressive one, the rest are not worth it IMHO.
    Look in the L99 dyno sticky and search there.
    YES, with the correct length and you'll know what size when you choose the cam, the company will let you know what the correct length is with their cam (as long as you don't mill the heads)
Of course you do, a set of Brian Tooley platinum springs, and do the comp trunnions upgrade along with a katech C5r timing chain and deleting the chain tensioner with an Ls2 dampner.
Your welcome.
Old 05-24-2013, 01:25 PM   #12
flyer08
Drives: 2010 2SS/RS
I also forgot tsp list Dyno numbers on their website but its tricky to find. There is a very small icon you can't really make out what it's supposed to be above the description of each cam. Click that
Old 05-24-2013, 01:43 PM   #13
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Under 5k? Thats nice man.
Old 05-24-2013, 02:02 PM   #14
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Why not do the LS7 or LS9 cams? GMHTP did a low buck swap of am LS9 cam on an AFM 6.2 with the LS3 springs,chain and cover and got 50hp 39tq.
2010 2SS/RS A6 DD K/N CAI
60ft 2.03 13.08 at 107.82 (4/28)
102SS is offline   Reply With Quote
