ADM PERFORMANCE
Old 05-23-2013, 09:52 PM   #1
stt816
Drives: 2012 Black 2SS/RS M6
Question Suspension Questions: ZL1 vs. 1LE Sway Bars
in the process of doing a suspension overhaul. I am getting drop springs. I am getting new rims (keeping stock pirelli's) and getting sway bars. From my understanding for rims (with stock tires) it is better to go with 20x9 all around (square setup) opposed to staggered 20x9 front 20x10 rear... so in the future once these tires wear out I will also continue with the square tire setup like the 1LE has...That being said I want to buy either the 1LE or ZL1 sways. Heard 1LE is better for square but ZL1 is better for Staggered. Since I would be staggered for now until tires wear out, what would you do if you were in my position... I do not drag race, just aggressive street driving. Thanks.
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|Factory Reproductions Type 41 Satin 20x9 Rims|General Tire G-Max AS-03 275/40/20 Square Setup|3M 1080 Matte Black Vinyl Wrapped Hood|Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback
--Jannetty Racing Enterprises Dyno Tuned|408 RWHP
stt816 is offline   Reply With Quote
Old 05-23-2013, 10:15 PM   #2
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
I'd go with 20x10 all around instead. The 1LE or ZL1 sway bars will make your 9" rears really loose. Remember that both the 1LE and ZL1 both have 10" rears.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 05-23-2013, 10:17 PM   #3
stt816
stock tires wont fit 20x10 up front though right?
Old 05-23-2013, 10:38 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2014 Summit White 2SS/RS 1LE
Disagree I love our ZL1 sways with our 20x9 275's all around set up the car is very neutral when pushing it hard into the corners and just has a "slight" bit of on throttle oversteer from the apex out. Car sticks amazingly well threw the slalom best set up so far but we are running a bit of camber front and rear also
2018 ZL1 1LE on order, Summit White, PDR, NAV
**FOR SALE**http://www.camaro5.com/forums/showthread.php?t=5003112014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Elite Gen2 CC, ZL1 splash guards, ZL1 pedals, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's on HoosierStone Tires, Previous Car: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98 FS
ICTsccaCamaro is offline   Reply With Quote
Old 05-23-2013, 10:57 PM   #5
stt816
hmmm interesting, so you would say zl1 over 1le sways?
Old 05-24-2013, 10:03 AM   #6
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Or you can go with the PFADT ZL-Spec Front & Rear Adjustable Sway Bars!!
PM or Call me with any questions.
Thanks
JT
Team STILLEN is offline   Reply With Quote
Old 05-24-2013, 10:11 AM   #7
stt816
yeah I bet those pfadt's are great, wanted the zl1 or 1le bars because they are significantly cheaper and I don't use the track, so either one of the zl1 or 1le bars would be fine for me, just trying to figure out which one
Old 05-24-2013, 10:42 AM   #8
Team STILLEN
Drives: Varies
Not sure what the price is on the ZL1 or 1LE Sways but PFADT also has their Sport Sway bars at a good price!
Old 05-24-2013, 06:54 PM   #9
ICTsccaCamaro
ITCRNRS
ZL1 and 1LE have the same part number rear sway bar, and the 1LE front sway bar is only 1mm larger than the ZL1 front sway bar so really there is just a very small difference, we bought our zl1 sways long before the 1LE was even heard of but if I were you I would go 1LE for the 1mm larger front sway
Old 05-25-2013, 07:15 PM   #10
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
That's the set up I'm working towards. Staying with the stock staggered wheels for now. ZL1 rear sway and the 1LE front bar. Both are OE stock with stock links. Right now I'm waiting on the front links. They have been on back order. Rear sway is on. Not planning on tracking it. Just get a little better plant in the corners.
For now.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 05-26-2013, 07:08 PM   #11
ICTsccaCamaro
ITCRNRS
Youll need to hit a few local autocrosses to make sure all that hard earned money is working correctly in the corners
Old 05-27-2013, 10:31 PM   #12
L99CAMA2011
L99CAMA2011's Avatar
Thanks
JT
These rims at 22.8lbs, Pfadt ZL-1 sways and radius rod bushing mod would put your in good standing. Stock 20x9s are still heavy is heck 37lbs vs 22.8 lbs do the math. Lighter wheels will make your steering quicker and make the car feel more nimble also quicker with reduced rotational mass.
Old 05-27-2013, 10:42 PM   #13
sycraft
COTW 5/06/2013
sycraft's Avatar
I had the 1 LE bars, changed to the LSR Bars and really love them, excellent pricing too. Call Rodney at LSR..
http://www.lsrperformance.com/camaro-suspension.html
Old 02-05-2014, 07:30 PM   #14
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
That is false,
Wheels 20x10 Black ( ZL1-1LE ) - 22798741
Wheels 20x11 Black ( ZL1-1LE ) - 22798743
Just trying to help out.
Ir0nM4n is offline   Reply With Quote
