Gen5DIY
Old 05-24-2013, 11:46 PM   #1
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
My Carbon Fiber Project
So after weeks of gathering supplies and parts and doing a ton of research, school is out and so I am finally ready to start my carbon fiber project of wrapping interior parts in real carbon fiber. I will post my steps and progress on this thread as I go, this will probably take a while as I plan on doing a lot of parts. Based on what others have told me I am fully prepared to screw up my first few tries but hopefully in the end it will all work out!
Aubrey64 is offline   Reply With Quote
Old 05-24-2013, 11:47 PM   #2
Aubrey64
Aubrey64's Avatar
Here is a picture of most of my parts/supplies:
Here is what I have here:
- Real Carbon Fiber Cloth
- Resin
- Hardener
- Mixing Cups
- Kitchen Scale
- Stirring Utensils
- Black Spray Paint
- Heat Gun
- Dremel With Various Routing Bits
- Sharp Knives
- Gloves
- Sand Paper
- File
I think I am gonna start out with the driver side dash trim and the A/C bezel and then go from there
Old 05-24-2013, 11:47 PM   #3
Aubrey64
Aubrey64's Avatar
I am setting up a work area in my garage tomorrow, and am gonna get started then. So I'll post some more pictures soon
Old 05-24-2013, 11:49 PM   #4
blackTT600
Drives: 2011 2LT M6 SC
good luck!
blackTT600 is offline   Reply With Quote
Old 05-25-2013, 01:01 AM   #5
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Looking forward to seeing how this goes! Good luck.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 05-25-2013, 10:39 AM   #6
MackMan
Camaro CRAZY
MackMan's Avatar
Drives: 2010 2SS/RS IOM
can't wait to see how this goes. I want to do this myself.
MackMan is offline   Reply With Quote
Old 05-27-2013, 01:16 AM   #7
Aubrey64
Aubrey64's Avatar
Day 1:
So far so good (I hope!) So today, I set up my work station in my garage, nothing special
Name:  Work station.jpeg
Now for what I have done so far. I decided to start out with small and flat parts, so I went with the center A/C Vent and the drivers side dash trim. I know it isn't a lot, but I thought it would be good practice.
first, I sanded them with 100 grit sand paper.
Next, I sprayed them with black spray paint. I did a couple of thin coats, nothing too much, but this was just so that if the carbon fiber was to separate, you wouldn't see the silver.
Now that the parts are prepped, I then cut out the carbon fiber to the appropriate size.
I am gonna start the wrapping in the morning, so this is all I have for today. But more will come tomorrow
Old 05-27-2013, 01:17 AM   #8
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
looking good.
Old 05-27-2013, 03:06 AM   #9
kobSS
kobSS's Avatar
Drives: 2010 2SS/RS
Great job so far. Keep taking your time and I'm sure everything will come out just like you plan. Looking forward to the end results.
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers
"Information is the oxygen of the modern age"
Build Thread
kobSS is offline   Reply With Quote
Old 05-27-2013, 03:23 AM   #10
rberns
rberns's Avatar
did you tape the end of the carbon fiber to prevent them from fraying (sp?)
Old 05-27-2013, 03:23 AM   #11
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Good luck with them. The better the weather out, the better they seem to dry.
Inferno LSX is offline   Reply With Quote
Old 05-27-2013, 12:53 PM   #12
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Yes. Also helps keep the weave straight.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 05-27-2013, 01:48 PM   #13
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Nice job so far thanks for posting
IOM Black Diamond is offline   Reply With Quote
Old 05-27-2013, 06:42 PM   #14
Aubrey64
Aubrey64's Avatar
Thanks guys for the comments and input, and if anyone has any suggestions on things I can improve, please let me know!
Day 2
Today I started actually wrapping the two pieces, the A/C vent came out pretty good I think (so far) but I am not sure about the dash trim, I may end up having to redo that piece, but I will wait and see. Here is what I have so far
What I did was mix the Resin/Hardener to a 2:1 Ratio, and then I applied the mixture to the parts, and then let it get tacky before applying the carbon fiber, and then I just worked the carbon fiber around the part.
I am gonna apply the first layer of the Resin/Hardener on top of the carbon fiber once it is stuck fully onto the parts, so more will come soon
