Old 05-25-2013, 02:17 AM   #1
Threlkeld's SS
Threlkeld's SS's Avatar
Drives: 2010 camaro ss
16 codes after header install?
I recently put tsp lts on my camaro and afterwards I checked the codes at the local parts store and I had 16 codes! Is that right? I mean they all had something to do with SENSOR #2 which was deleted with the install. So my question is should I be worried?
Threlkeld's SS is offline   Reply With Quote
Old 05-25-2013, 02:25 AM   #2
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
If yu are not worried about your warranty get it tuned by a good tuner, those codes will be gone.
CHMSC is offline   Reply With Quote
Old 05-25-2013, 03:33 AM   #3
Denis
Denis's Avatar
Drives: 2010 SS
You need to have a tuner remove those sensors. Otherwise those codes will stay.
Old 05-25-2013, 08:10 AM   #4
MARKS5LTRETR
I'm a lucky dude
MARKS5LTRETR's Avatar
Drives: 2010 SIM 2SS/RS #1226
16 codes and what do u get ...a trip to the tuner and deeper in debt.
KB supercharged, Meth injected, Kooks sig series, Corsa cat back, Eibach pro kit, engine mods by me, Tuned by Next Level Performance, 2 tons of fun.
MARKS5LTRETR is offline   Reply With Quote
Old 05-25-2013, 08:21 AM   #5
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 05-25-2013, 08:23 AM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
I doubt they all came from your header install. Id bet you had several of those in your computer's history before the CEL would come on.
If you did the air and egr delete, you'd have more than just the rear O2s throw a code.
Phil
Tampa Tuning is offline   Reply With Quote
Old 05-25-2013, 11:10 AM   #7
Threlkeld's SS
Naw the only ting I did was install tsp's 1 7/8 lts
Old 05-25-2013, 01:16 PM   #8
ForgedReality
Envy
ForgedReality's Avatar
Drives: 2011 SGM 2SS/RS - Black hood/hockey
Just do the spark plug defouler trick, and you don't have to tune out the sensors, and the computer won't put the engine into starvation mode. Everything will be fine. And for less than $5.
ForgedReality is offline   Reply With Quote
Old 05-25-2013, 01:43 PM   #9
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
What is the " spark plug defouler trick"??
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Old 05-25-2013, 01:57 PM   #10
mikeyg36
mikeyg36's Avatar
Old 05-25-2013, 02:17 PM   #11
Threlkeld's SS
Ok I just removed my plugs should they look like this
Old 05-25-2013, 02:38 PM   #12
matt55
matt55's Avatar
Drives: CTS-V
Something that DOESN'T work on our cars . Been fighting that fight for over a year.
After header install and completing a couple "drive cycles" the light will trun on.
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 05-25-2013, 02:48 PM   #13
ForgedReality
Envy
You have to use two defoulers per side. You drill one out with a half inch drill bit, and the sensor goes in that one. You screw another one onto the end of that, and that defouler goes into the exhaust. It works. Don't drill out all the way to the end, just make it so that the end of the sensor basically touches the bottom of the drilled out hole in the first defouler. Usually it doesn't work because you did it wrong.
Old 05-25-2013, 03:13 PM   #14
Devilfish
US Navy Chief
Devilfish's Avatar
Drives: Camaro Sold
The plug itself doesn't look that bad. It does look like you have some oil on the threads though.
Devilfish is offline   Reply With Quote
