HeadlightArmor
Old 05-25-2013, 07:35 AM   #1
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
New 2ss water spots
So I pulled out the closet last night I have:
Meg UC
Meg UP
Meg 205
Menzerna Fg400
Menzerna Sp4500
BF GEP
XMIT 360
Ultima prep
What to use for water spots....hmmmmmmm
Glen e is online now   Reply With Quote
Old 05-25-2013, 07:46 AM   #2
family man
Drives: .
Will a clay bar take care of these? It's probably a good start to get rid of any grit/dirt that may have built up on the car. Did it sit on a dealers lot for a while?
family man is offline   Reply With Quote
Old 05-25-2013, 07:50 AM   #3
Glen e
Glen e's Avatar
Yeah plan to use a speedy prep towel first ....days on lot was about 100....
Old 05-25-2013, 08:01 AM   #4
Rockey33
Rockey33's Avatar
Drives: 2012 IOM Camaro SS
I used Meguiars UC on my new Jeep that had water spots. It took them right out.
Rockey33 is offline   Reply With Quote
Old 05-25-2013, 08:02 AM   #5
habunow1
habunow1's Avatar
Drives: 2010 Yellow 2SS, 2011 CG 1LT IPF SC
If your car is black plan on having water spots all the time. After washing it use detailer spray and a good microfiber towel.
habunow1 is offline   Reply With Quote
Old 05-25-2013, 08:28 AM   #6
Glen e
Glen e's Avatar
red car...no problems...if you have black look into a wipe walk away polymer sealant - really changes the way you maintain dark cars...soooo much easier...
Old 05-25-2013, 08:38 AM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You might as well clay, polish, glaze, seal, and wax the whole thing. Wish I would have done that to my car first thing. Wouldn't think you'd need anything grittier than UC or even UP.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-25-2013, 08:42 AM   #8
Glen e
Glen e's Avatar
Oh I certainly plan to - my master plan that works for me is:
1. clay/speedy to clean paint
2. one of the above to elim any imperfections
3. Blackfire Gloss Enhancing Polish- griots DA/CCS white pad
4. (Probably) Blackfire Wet diamond - DA with blue pad
5. Two coats Blackfire Crystal seal ( the real magic)
Old 05-25-2013, 09:06 AM   #9
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
Probably goes without saying,but your first step really should be a 2 bucket wash. I personally leave the car wet and go straight to Claying before drying. Your local water condition will dictate whether or not you can do this as well.
While clay / prep towel will remove imbedded contaminates, if you clay without washing first, you'll damage your surface and your polishing step will take a lot longer to fix.
Also, Black car, red car, what ever color car, the color doesn't matter. They all have a clear coat on top of them which is what you're actually fixing and it doesn't care what color the base coat below it is. Your fix is on the clear coat surface should be the same regardless of base coat color.
WiSSDiver is offline   Reply With Quote
Old 05-25-2013, 09:15 AM   #10
Glen e
Glen e's Avatar
Thanks... Been detailing for years...certainly a wash either with my foam gun or rinselesd is how we start ... Actually just wondering how the paint is for initial correction...
I hear "its hard but is delicate".. So goes the water based urethanes!
while I agree the "clear is clear", I respectfully disagree, blacks show need of correction far quicker that other colors like silver or white...color does matter...
At this point I think I'll try UC with a soft pad...it's very pad dependant...
Old 05-25-2013, 09:27 AM   #11
WiSSDiver
WiSSDiver's Avatar
To a point, I agree that the black makes the scratches and swirls easier to see without additional light, but your still fixing the clear coat in the same manner regardless of the color. I think we agree though.
Old 05-25-2013, 09:29 AM   #12
Glen e
Glen e's Avatar
yes we do..you do it no diff...it just SHOWS faster, I guess is what I'm saying, that being said, putting a hard polymer shell or opti coat slows it down a bit!
Old 05-25-2013, 09:34 AM   #13
WiSSDiver
WiSSDiver's Avatar
Oh heck yeah.
Old 05-25-2013, 09:34 AM   #14
WiSSDiver
WiSSDiver's Avatar
BTW Glen, welcome to the forum!
