BORLA
Old 05-25-2013, 11:52 AM   #1
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Caliper pin help needed
I took my pins out re lubed them , Then forgot which one is the top pin , 1 is gold colored , the other is silver with a black plastic that turns on the pin , I am not sure which one iis the top and which one is the bottom any help is greatly appreciated , thanks
MBS is offline   Reply With Quote
Old 05-25-2013, 01:22 PM   #2
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Anyone ?, I am the only one to ever yank them both out and forget which is which ?
Old 05-25-2013, 01:33 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Did you remove the pins from all the calipers?
Click to view my build thread
Old 05-25-2013, 01:56 PM   #4
SPCBA
Drives: pleather and Chiclets
Sorry have no clue about v6 brakes. the pins are all the same on mine. Try asking in the v6 bolt on forum you might get a answer or two before the mods move the thread here
SPCBA is offline   Reply With Quote
Old 05-25-2013, 01:59 PM   #5
The Stig
The Stig's Avatar
Have you checked out some of lithe brake pad swap DIYs? They might tell you.
Old 05-25-2013, 02:08 PM   #6
Mr pogo
Drives: 96 Imp SS, 13 Camaro 2SS AGM
I looked at my online GM service and parts sources and they do not say
V6s have the Bosch formerly Bendix style brakes so maybe this helps.
the medium duty truck hydraulic brakes versions use a similar metal/plastic slide pin setup IIRC to prevent seizing and chattering, look at pages 10 and 11.
http://www.weindex.info/pdf/Brake/2.pdf
http://www.camaro5.com/forums/image.php?type=sigpic&userid=71668&dateline=136924  9466
Mr pogo is offline   Reply With Quote
Old 05-25-2013, 02:45 PM   #7
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Thanks for the replies guys , The rear brakes are no problem they are the same , The fronts are the ones I have the issue with
Old 05-25-2013, 02:51 PM   #8
MBS
MBS's Avatar
Drives: 2010 rs 2lt
There it is , that link for Bosch had them listed THANK YOU SO MUCH !!! The ones with the plastic bushing are the bottom pins , They are the silver pins , the gold pins go on the top. Whew I knew I could get the answer on this site , Thanks again guys , Jeez am I the only one ever to do this , I searched this forum hard and could find no reference to it ,
Old 05-25-2013, 02:52 PM   #9
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Thanks for the help Stig , You are so helpful on all subjects
Old 05-25-2013, 06:21 PM   #10
The Stig
The Stig's Avatar
We're you able to find a DIY with the answer? I know the DIY Index sticky has four or five threads on swapping brakes.
Old 05-25-2013, 09:34 PM   #11
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Mr Pogo posted this link , http://www.weindex.info/pdf/Brake/2.pdf
It broke down all the parts real nice , The way they should be installed in great detail. Thanks for your suggestions and the time you took it is appreciated.
I got the Baer drilled and slotted rotors on , with the EBC yellowstuff pads , and goodrich stainless on , Tomorrow I bled it out with Mogel dot 4 and I should be all set !!
