Anthony @ LG Motorsports
Old 05-25-2013, 07:36 PM   #1
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Clutch Fluid vs Brake Fluid
If you separate the clutch and brake fluid reservoirs is there really any benefit to running higher temp clutch fluid such as Motul 600? Is the clutch fluid really going to see high enough temps even during a HPDE track event to require higher temp fluid?
I'm hoping maybe some of you more experienced track drivers can help chime in here and provide your thoughts.
Thanks.
Nick S.
Nick S is offline   Reply With Quote
Old 05-25-2013, 07:43 PM   #2
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
I think my clutch feels better with motul. Not sure on the rest. I could be wrong but I don't think the clutch fluid would get as hot as the brakes.
CHMSC is offline   Reply With Quote
Old 05-25-2013, 07:43 PM   #3
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
That i dont know but it wont be long til someone does.I do know that you definitely want to separate the two.I change my clutch fluid every tank,as it gets dirty so fast,couldn't imagine having that fluid in my brake lines.
cornerspeed92 is offline   Reply With Quote
Old 05-25-2013, 07:48 PM   #4
Nick S
Nick S's Avatar
When you change your clutch fluid do you bleed out the entire system with new or do you just remove all the old from the reservoir and replace it with new and then just pump the clutch several times to distribute the new fluid?
Old 05-25-2013, 07:56 PM   #5
cornerspeed92
I empty, refill, pump 30 times, 5 or 6 times,the fluid will start to look not so golden brown.
Old 05-25-2013, 08:44 PM   #6
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red 1979 Z28, HBM 2016 1SS
Thumbs up
I change my clutch fluid the same way, just not as frequently. My car mostly just goes to work and back with a little spirited driving mixed in. When I see the fluid anything other than clear, I do what CS92 does above. Since I seperated the clutch from the brake, the brake fluid has remained crystal clear.
Tara
I use DOT4, of course...
Okay, ok; I know where my Camaro is now! In my driveway!
Tara Martin is offline   Reply With Quote
Old 05-26-2013, 12:36 AM   #7
con10der
Con10der
con10der's Avatar
Drives: 2010 2SS/RS M6 IOM Rally Stripes
So how do you empty the reservoir? Syringe?
2010 2SS/RS M6 IOM w/Rally Stripes. BLK CAI w/ADM,WW Relo,2" Kooks,3" Cats-Mids,Vmax Ported TB,Muff Del,Janetty SCT Tuned,Drill/Slot BLK Hawk rotors,Red Grani Brake Lines,Motul 600,IDEAL Master w/res,Moroso CC,Accel Silver Tips w/TVolt 10.4mm,MGW shift w/Retro hand/ball,ABL Kit,Billet/IOM pedals, ZL1 split,Lloyds SS mats,PC Droid4/MAXX docking,HW Solo2.
Pend Install: Launch/Shift Light,BMR Susp/1" Drop/Sways/Track Pack,GM 3.9. Future: Janetty Pumpkin w/PosiTrac,1400HP axl,CF DS,Tick Stage 2 Trans,3 Disc Clutch,4"quad tip,center exit AB w/diff...
con10der is offline   Reply With Quote
Old 05-26-2013, 12:58 AM   #8
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Yes, use a syringe to drain it the best you can. Then disconnect everything and install the new reservoir and clutch reservoir and bleed the brakes and the clutch.
Old 05-26-2013, 01:24 AM   #9
con10der
Con10der
con10der's Avatar
So if I am just trying to flush stock reservoir, just suck out with syringe until very low then refill, pump clutch and then repeat process several times?
Old 05-26-2013, 01:33 AM   #10
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Depends on how much you are trying to flush it. If you just want it kinda clean suck out the fluid but don't go to low and get air in. Put fresh fluid in and Pump the brakes and the clutch and repeat till its clean or cleaner. If you want it really clean you need to bleed the brakes and the clutch from the bleeders. Just remember you won't be able to bleed the abs system unless you own a tech II scan tool or take it to the dealer so they can do it.
Old 05-26-2013, 02:38 AM   #11
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
I use a meat injector like this without the metal needle. Works insanely great with no mess.
Sent from my iPad using Tapatalk HD
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 05-26-2013, 03:17 AM   #12
Tara Martin
Loves Camaros
I use the big syringe from a two-stroke oil mix kit from Wally-Mart.
Tara
Old 05-26-2013, 10:15 PM   #13
cornerspeed92
I have one from the vet, when stupid ass Max(the cat)decided to make me spend $400.00 to save him......stupid cat,just kidding, he's pretty cool.
