Old 05-25-2013, 07:46 PM   #1
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Flushing Brake System when still New
I have a 2013 1LE with only 900 miles on it. I was going to flush the factory brake fluid out and replace it with Motul 600. But the factory fluid is still so new that I don't think I'll be able to tell when the old fluid is flushed out of each line and the new fluid starts. Does anyone have any recommendations as far as how to monitor the amount of fluid you pass through each brake line set before you can be fairly certain you have flushed all the old fluid out?
I have a power bleeder so I was thinking of trying to just pressurizing the brake fluid reservoir and not allowing new fluid to replace the old as it runs out. I figured I could monitor the level on the brake fluid reservoir and know that once I have bled out half the reservoir then maybe I could consider that corner fully bled.
Or is there a certain volume measurement that can be targeted from each corner. If each brake line set holds say 1/2 quart or something then I could just bleed each corner until I have bled out a 1/2 quart from each corner.
Thanks in advance for any help/advice.
Nick.
Nick S is offline   Reply With Quote
Old 05-25-2013, 08:01 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Easiest way would be to do a tech II bleed
Click to view my build thread
Old 05-25-2013, 08:04 PM   #3
Nick S
Nick S's Avatar
I wonder how much my dealer would charge to do that? Has anyone else had their dealer perform this and can share what their cost was for the service?
Old 05-25-2013, 08:08 PM   #4
The Stig
The Stig's Avatar
Service manual says its about an hour. Should be cheaper if you supply the fluid.
Old 05-26-2013, 09:39 PM   #5
Nick S
Nick S's Avatar
Well after seeing how golden brown my fluid is already after only 900 miles (before my clutch reservoir was separated) I'm thinking I'll be able to see a color difference between factory fill and the Motul 600. I still might take it to the dealer though for the first time just so I know the entire system including the ABS system has been bled out with Motul 600.
Old 05-30-2013, 02:49 PM   #6
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I used Blue on my last car and you can really tell when the old stuff is out.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 05-30-2013, 03:58 PM   #7
Nick S
Nick S's Avatar
Thanks. I've seen the ATE Super Blue. But I already have Motul 600 which is not colored. But as I noticed how golden colored the fluid in my reservoir already was after only 923 miles, I think by the time I get around to bleeding the system with new fluid I'll probably be able to see the difference. Won't be as easy as seeing the blue color but I think it should be noticeable enough.
Old 05-30-2013, 04:17 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
You should be able to see the difference even though it will be slight. My fluid was the same way and I could see the new fluid. I did mine by hand though. Use two bottles to do it all.
Build Journal
Old 05-30-2013, 04:51 PM   #9
Nick S
Nick S's Avatar
Yup, I actually have 3 bottles ready for the flush job.
