Old 05-25-2013, 08:15 PM   #1
Rock on
Rock on's Avatar
Drives: black 2011 2ss
Question for all you cammed and stalled Guys
I recently had my cam and stall installed and when coasting the engine surges about 100 to 150 rpm almost like a slow lope is this normal for these cars? My 68 firebird has a milder set up 2800 stall and it does not do this.
FASTER THAN A SPEEDING TICKET 2011 cammed 3600 stall 68 cammed 2800 stall
Rock on is offline   Reply With Quote
Old 05-25-2013, 11:19 PM   #2
JEFF75645
Drives: his wife crazy buying mods
Mine does the same thing in the lower gears while using the tap shift. I will shift to 2nd or 3rd and it will shift and then surge slightly a few seconds later.
Not sure if this is what your talking about or if its normal.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 05-25-2013, 11:31 PM   #3
Rock on
Rock on's Avatar
It doesn't do it if the rpms are up only when coasting but sounds like the same thing
Old 05-25-2013, 11:34 PM   #4
JEFF75645
Yep. Mine only does it while coasting or light throttle. I tried to record it the other day but could get a good video since its a slight surge.
Old 05-25-2013, 11:35 PM   #5
Rock on
Rock on's Avatar
exactly
Old 05-25-2013, 11:36 PM   #6
Rock on
Rock on's Avatar
what size is your cam
Old 05-25-2013, 11:37 PM   #7
JEFF75645
223/236. can't remember lift or LSA. With 3200 circle d stall.
Old 05-25-2013, 11:41 PM   #8
Rock on
Rock on's Avatar
thanks for reply
Old 05-26-2013, 01:17 PM   #9
JEFF75645
I'm still curious as to what causes this.
Old 05-26-2013, 02:04 PM   #10
drayco513
drayco513's Avatar
Drives: ss2/rs
mine surges from 1000 to 900 most of the time. its suppost to be 950 so i think thats normal.
461/423 n/a
drayco513 is offline   Reply With Quote
