JUICEDMOTORSPORTS
Old 05-26-2013, 12:12 AM   #1
Bauer2
Bauer2's Avatar
Drives: 2013 2SS/1LE and 2009 R1
Diff fluid Change
For anyone wondering why its good to change the fluid right after getting the car here are some pics.
Car has 1500 miles on it to give you an idea.
Drain plug on the left and fill plug on the right. The rag shows all the crap that came off both plugs and the fluid in the bucket had a definite metallic look to it. Ignore the leaf and grass that definitely didn't come out of the Diff.
Bauer2 is offline   Reply With Quote
Old 05-26-2013, 09:09 AM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
When I did mine at the same mileage it looked similarly. The fluid looked like it was full of glitter too.
It's pretty normal for a freshly built rear end though. The engine oil looked like hell and the trans fluid was pretty good but the shift improvement from the new fluid was worth it.
Firefighter is offline   Reply With Quote
Old 05-26-2013, 09:24 AM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I changed ours for the 1st time ar 700 miles just before our 1st event with the car and it was just as black and burnt, its one of the 1st things I always suggest to a new 5th gen owner. I changed it again at 5000 miles and then at 10000 miles and it looks great compared to the first time
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 05-26-2013, 09:46 AM   #4
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
Is there a DIY on here for the change ?
Old 05-26-2013, 09:50 AM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes. Check the DIY Index Guide sticky
Click to view my build thread
Old 05-26-2013, 10:17 AM   #6
Firefighter
I added Dimple plugs all around when I swapped all my oils. The strength difference between the stock plugs and the Dimple's was astounding.
Having added those gives me a warm and fuzzy feeling. There's no way it can't be good.
Sent from my DROID RAZR HD
Old 05-26-2013, 05:04 PM   #7
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Any specific type of fluid you selected?
Phdpsy is offline   Reply With Quote
Old 05-26-2013, 05:22 PM   #8
Firefighter
If you were talking to me go to post #78 of this thread... http://www.camaro5.com/forums/showthread.php?t=285054
I explain it all and give my feed back.
Old 05-27-2013, 01:27 PM   #9
StephenS_84
Drives: 2011 2SS/RS
You sure about that? I didn't see one.
StephenS_84 is offline   Reply With Quote
Old 05-27-2013, 01:32 PM   #10
LIM3
LIM3's Avatar
Drives: SGM
I can't seem to find it either
Old 05-27-2013, 01:37 PM   #11
Firefighter
It's pretty easy on the drivers side (I believe) there are two plugs they use a 3/8" ratchet to remove. The bottom is drain the top is fill. Basically take out the top so you don't get a vacuum take out the bottom to drain. It takes a quart. Reverse procedure and fill with fluid of your choice, just make sure it has the limited slip additive. Get a hand pump to transfer the fluid into the diff.
All this is obviously while the car is properly raised and supported by jack stands.
Old 05-27-2013, 07:08 PM   #12
Bauer2
Bauer2's Avatar
I didn't even have to Jack mine up. Just backed it up to the small lip where the garage and dive way meet have me plenty of room. Helps if your drive way is sloped some.
I was able to get the fluid in with out a pump but a pump would make it easier. Just fill it back up till it starts coming out the fill hole then your done. Make sure the car is level when filling it up though.
Sent from the fast lane!
Old 05-28-2013, 06:44 AM   #13
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
What kind of oil is everyone using ?
chevy 3 is offline   Reply With Quote
Old 05-28-2013, 09:40 AM   #14
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
I use the factory oil #88900401 synthetic and factory LSD additive. I change mine after the 100 mile break-in procedure ( I did a SS diff swap ) and again after 1,500 miles.
etmx183 is offline   Reply With Quote
