Old 05-26-2013, 09:10 AM   #1
jmss
Drives: 2010 camaro ss
6l80 to 4l60 conversion
What parts would I need to do the swap?
jmss is offline   Reply With Quote
Old 05-26-2013, 10:23 AM   #2
Supercharged SS
Drives: 2010 Camaro
Why do you want to ditch the 6l80e? It's a great trans with the right people behind it.
Matt at FSP would be who you should contact about installing the 4l. Although he went from an m6 to the 4l, he'll know exactly what's needed to make it work.
Old 05-26-2013, 11:04 AM   #3
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Put down some real power Jamie and you'll think twice about saying that LOL.
Either way, yes I had a 4L60E in my car (Swapped in from a m6), so there are a few more items to take care of when swapping into a factory 6l80e car. Short list..
Flexplate
Converter
Trans
Trans Crossmember & Poly Mount
Dipstick
Driveshaft custom length (I can get you one from DSS)
Auto vs. Manual valve Body (Electronics?)
I have the stock 6L80E shifter in the car, with the stock shift rod. You'll need to do a bit of massaging to the stock shift rod to make it work. From my knowledge no one has made a trans crossmember yet, Doug @ ECS made mine for me one-off.
Also, the 4L60E requires you to massage the floorboards in on the passenger side tunnel (Yes get out the big hammer).
- Matt
Matt @ FSP is offline   Reply With Quote
Old 05-31-2013, 10:39 AM   #4
jmss
What trans controller would you use with 4l60
Old 05-31-2013, 11:47 AM   #5
Matt @ FSP
Matt @ FSP's Avatar
I used the OptiShift.. Between that or the PCS controller is usually what most use.
Old 05-31-2013, 06:37 PM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
also using the optishift
mikepage0007 is offline   Reply With Quote
Old 06-01-2013, 01:42 AM   #7
62nalide
62nalide's Avatar
Drives: 2013 SS
People still scared to push these 6L80Es? LOL my 2011 sierra Denali has been pushing 600-800rwhp for 2yrs just with a 3k converter I'm sure these cars can hold that easy unless your over 900rwhp
62nalide is offline   Reply With Quote
Old 06-01-2013, 09:41 AM   #8
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
my 6l80e started flaring the 3-4 shift after 2 weeks at 650whp.
im waiting on my new 4l80e from rpm right now. pcs controller here.
you guys both running stock shifter still?
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 06-04-2013, 02:16 PM   #9
se7en
Drives: 87 Pinto on 32's
A whole lot of patience
I opted for the hurst shifter to give it a nice "metal look" i guess, but ive seen the stock shifter in many.
se7en is offline   Reply With Quote
Old 06-04-2013, 02:17 PM   #10
se7en
Also that PCS Controller is very easy to work with and figure out if you do your own adjusting. If not even after a few times of going threw it, you will get the hang of it.
