Gen5DIY
Old 05-26-2013, 10:28 AM   #1
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Low miles High years maintenance
My car is over three years old, but has only 11,000 miles. Can someone please tell me what maintenance is needed, since the manual seems to link most to mileage?
Also, in regards to checking and adding coolant, the manual is confusing. When should the coolant be added to the overflow bottle vs. the radiator cap?
Lastly, has anyone been able to visually check the level of the rear axle fluid? The process seems open to error: "If the level is below the bottom of the filler plug hole, add some lubricant."
Thanks!
Inuyashas_Brother is offline   Reply With Quote
Old 06-03-2013, 02:28 AM   #2
mulletman
Drives: 2017 Camaro SS
Add coolant at the overflow bottle. Change the oil and filter at least once a year. Check the differential fluid on a level surface by removing the top fill plug. The fluid should be even with the bottom of the hole. Both the coolant level and differential fluid should be fine unless there is a leak.
mulletman is offline   Reply With Quote
Old 06-03-2013, 11:35 AM   #3
Avenging Orange
Avenging Orange's Avatar
Thats why the manual is mileage based. If you dont drive it there is no wear n tear. Oil is about the only thing to worry about. Im like you, have a 2010 with 13,000. Pretty much change the oil once or twice a year and Im golden. A lot of us more anal folks like to get the factory goo out of the rear and tranny (no homo).
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 40 years of not buying into the Hype........and damn proud of it!!
Old 06-05-2013, 07:17 AM   #4
thesaint
Drives: 2011 camaro ss/rs
I would treat years as the same as mileage if your going to keep your car and you care. Change your oil twice a year, short trip, low mile driving is also hard on oil. Coolant flush and change every 3yrs, its realy not that difficult. Brake fluid every 2yrs, it gets contanminated. Read end fluid every 2yrs, its only a quart.
Remember the manual is only a "guide" of bare minumum. They want to sell cars, not have us keep it good running order for a long time.
thesaint is offline   Reply With Quote
Old 06-11-2013, 06:59 PM   #5
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
The manual says to change the oil a minimum of once a year. Kinda killed me to dump my Mobil 1 after less than 1,000 miles since the last time I changed it. Last April
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
Old 06-12-2013, 11:49 PM   #6
Moser28
Drives: 2010 LT2 RS Coupe
I am new to the forum as I have just purchased a 2010 RS with 9200 miles. The oil change sticker on the window said to change it 10679 or 12/13/11 whichever was first. It's been sitting in a garage the whole time but had me a little worried. I immediately changed the oil with mobile one full synthetic and a wix filter so I hope I am ok.
Moser28 is offline   Reply With Quote
Old 06-13-2013, 09:43 PM   #7
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
I have a 2010 SS that I have had 2 yrs today. It has 8900km (that's about 5600miles). There is some good info from you guys in this thread. I will do a spring oil change and brake fluid flush/change. I will check the diff oil to be on the safe side.
Big C CamaroSS is offline   Reply With Quote
Old 06-14-2013, 08:03 AM   #8
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
You're fine with Mobil 1 and a Wix filter.
Hannibal is offline   Reply With Quote
coolant, low miles, maintenance, rear axle
