Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 05-26-2013, 11:22 AM   #1
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
How to make a car from 1969 pass registration?
What is everything I need to do to a car from 1969 to make it street legal? I saw someone driving around a beat up mustang and another driving around a skylark. What is everything that needs done assuming the frame and body are good to go.
LBreezie is offline   Reply With Quote
Old 05-26-2013, 12:37 PM   #2
LBreezie
LBreezie's Avatar
Originally Posted by NVmyZL1 View Post
I suggest you just sell the car to someone who knows something about cars.
What do you mean, what do you need to do? As long as the car has working lights, brakes and safety equipment the car was originally equipped with, you should be good to go.
Well im getting into cars, I just wanted to talk with you guys on the matter ,because I love going on the forums here just discussing things. I should do a disc brake conversion, make sure everything is fine with the lights, and put a sparco seat in there with a harness and it will be fine for inspection?
Old 05-26-2013, 04:40 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Again, I'm not sure of the specifics of vehicle inspections in PA, but as long as the car functions just as it did when it was built, you should be fine. Doesn't matter if you have disc or drum brakes, either.
This basically. The car qualifies as an antique vehicle, and if you register it as an antique vehicle you don't have to comply with current emissions/safety laws.
Click to view my build thread
Old 05-26-2013, 05:07 PM   #4
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Section"E"
http://www.dmv.state.pa.us/inspections/pub_45.shtml
MMC is offline   Reply With Quote
Old 05-26-2013, 05:20 PM   #5
arod55
AROD55
arod55's Avatar
Drives: 2010 Camaro 2SSRS/55 Chevy Bel Aire
FYI the 69 Camaro came with front disc brake. Most states and here in California you don't have to worry about smog laws.
arod55 is offline   Reply With Quote
Old 05-27-2013, 01:12 PM   #6
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
Not all '69s had front disc....
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
Old 05-27-2013, 04:53 PM   #7
The Stig
The Stig's Avatar
Correct. It was an option.
Old 05-27-2013, 06:27 PM   #8
LWM
LWM's Avatar
Drives: #54 ZL 550 CGM Camaro 2SS/RS,GIF
Right on..... Stig. I just registered a 68 SS/RS 396/350 here in VA. I only had to certify the car met road worthy safety requirements and presented the notarized form to DMV. No Safety inspection required.
LWM is offline   Reply With Quote
Old 05-27-2013, 06:41 PM   #9
The Stig
The Stig's Avatar
Nice. Told you you didn't need no safety inspection.
Where in VA are you?
Old 05-27-2013, 11:13 PM   #10
macalot
Drives: 1969 + 2015 Z/28s F250 SD
The simple answer is that you need most everything that came on a base car functioning with some exceptions. There is no emissions tests for any model before '73 i think. You can change out most anything as long as the car isn't classified as a "specialty or reconstructed vehicle" which I understand to mean that the ride height is dramatically changed, or the frame is altered or similar modifications.
macalot is offline   Reply With Quote
