Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > General Camaro Forums > 5th Gen Camaro SS LS LT General Discussions
Old 05-26-2013, 12:15 PM   #1
Black Beast
Black Beast's Avatar
Drives: 2010 Camaro 2SS LS3
New SPEC clutch/flywheel. Need Reviews
I was wondering if anyone has used this setup (description below) and could tell me if its a good choice. I like it b/c it's a straight bolt on (no shimming required) so install should be faster and easier. Just wanted to be sure its worth my money. All comments welcome
2010, 2011, 2012, 2013 Camaro SS SPEC PT-Trim Super Twin Clutch and Flywheel #SC66SST
*Organic disk, includes flywheel
SPEC Clutches and Flywheels introduces the Super Twin for street and track use in cars with extreme horsepower and torque.
Until now, there has been a drivability, maintenance and longevity trade-off with clutches built to handle 900 ft lbs tq. The revolutionary new SPEC Super Twin has set a new standard offering near-stock drivability, tremendous life expectancy, a no shimming/setup bolt-in installation and maintenance free operation.
With all billet construction, these units are smooth and quiet. The super twin is constructed with aircraft grade aluminum and high carbon billet steel milled to an industry leading .001 inch for perfect balance and actuation.
Friction is provided by dampened, full-faced carbon graphite discs. Organic or full metallic options are available.
Torque capacities upwards of 1795 ft/lbs can be obtained depending on disc options.
Flywheel and track-spec hardware are included in each kit. All units include flywheel, high strength bolts and bearings. Installation is bolt-in with no shimming or setup required.
The ST-Trim Super Twin clutch is designed for street driving, drift & drag racing applications. Kit includes the clutch/pressure plate assembly, billet slave cylinder, master cylinder and alignment tool.
Read more:
Black Beast is offline   Reply With Quote
clutch, flywheel, spec
