sjm autoprod
Old 05-26-2013, 03:20 PM   #1
thjr59
thjr59's Avatar
Drives: 2010 Camaro SS IOM
stabilitrack message after header install
I finally put headers on my car and it was a handful. Now I drive it and the stabilitrack message comes on. Anyone have an idea what it could be.
thjr59 is offline   Reply With Quote
Old 05-26-2013, 03:29 PM   #2
omgitsmikeyC
Drives: 2014 CTS-V Coupe
But loads of torque management and a computer tune issue
2014 CTS-V... with some go-fast bits coming
omgitsmikeyC is offline   Reply With Quote
Old 05-26-2013, 03:32 PM   #3
SPCBA
Drives: pleather and Chiclets
mine was a cracked spark plug after header install..never threw a cel just gave the stabilitrack message. its like the one message fits all for our car.
SPCBA is offline   Reply With Quote
Old 05-26-2013, 03:34 PM   #4
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
Did you remove the spark plugs before install?
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 05-26-2013, 04:16 PM   #5
Devilfish
US Navy Chief
Devilfish's Avatar
Drives: Camaro Sold
Check your plug wires.
Devilfish is offline   Reply With Quote
Old 05-26-2013, 04:18 PM   #6
white ZL1
Drives: none
Misfires, for some reason or another.
white ZL1 is offline   Reply With Quote
Old 05-26-2013, 04:31 PM   #7
omgitsmikeyC
Any other sensors he could have hit? Tps or crank sensor?
Old 05-26-2013, 05:10 PM   #8
Denis
Denis's Avatar
Drives: 2010 SS
Cracked spark plug. Had the exact same issue. Check em!!
Old 05-26-2013, 06:17 PM   #9
JOHNSON SPEED SHOP
Drives: 2010 Camaro 2 SS/RS
Loose plug wire.
JOHNSON SPEED SHOP is offline   Reply With Quote
Old 05-26-2013, 06:26 PM   #10
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Anybody know the exact size for the spark plugs is it a 14 or 15mm?
Nightmare2012 is offline   Reply With Quote
Old 05-26-2013, 06:54 PM   #11
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
5/8 is the correct size.
LSX Camaro is offline   Reply With Quote
Old 05-26-2013, 07:17 PM   #12
thjr59
thjr59's Avatar
Yes I did.
Old 05-26-2013, 08:43 PM   #13
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Do you have a code reader? May have a code showing which cylinder is misfiring.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 05-26-2013, 08:44 PM   #14
mikeyg36
mikeyg36's Avatar
Originally Posted by thjr59 View Post
Yes I did.
Hmmm. Check plug wires then.
