Old 05-26-2013, 05:15 PM   #1
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Ebay turbo problems and the cure!
I finally pulled the trigger and ordered a Turbonetics turbo to replace the Ebay special that was installed on the car. Anyone who has seen my build thread here: http://www.camaro5.com/forums/showthread.php?t=47925 knows the long, long road I have taken to get this car running correctly. The shop that did the work went out of business after I picked up my car and had installed nothing but junk and substandard parts. Anyway, here are some pics of the Turbonetics turbo and the EBay special.
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 05-26-2013, 05:17 PM   #2
FrankT
FrankT's Avatar
Pics:
Old 05-26-2013, 05:21 PM   #3
FrankT
FrankT's Avatar
The main problem was excessive white smoke on deceleration after a hard run. I disassembled the turbo and found the oil seal had failed on the turbine side. There is no oil in the intake pipes or compressor side of the turbo, but I am contemplating removing the intercooler to see if any oil is inside it.
Old 05-26-2013, 09:07 PM   #4
Nessal
Drives: Exige, Miata, Ghia
Ebay....turbo kit....sigh.....
Nessal is offline   Reply With Quote
Old 05-27-2013, 11:59 AM   #5
FrankT
FrankT's Avatar
Umm... not a EBay turbo kit. A shop in FL fabbed the kit up and we were promised a Garrett turbo. What we got was a Chinese knock off like that is sold on EBay. Not to mention a crap tune and substandard work. Four cars were done mine being the last one.
Old 05-27-2013, 03:30 PM   #6
jordan 572
jordan 572's Avatar
Drives: none
Is that the new turbonetics with the 75mm on the hot side? Did you go with the 76 or 78 up front?
jordan 572 is offline   Reply With Quote
Old 05-27-2013, 06:42 PM   #7
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Who was the shop?
JLE58 is offline   Reply With Quote
Old 05-27-2013, 07:13 PM   #8
FrankT
FrankT's Avatar
It's a 78 on the compressor side. .96 A/R. Just a plain journal bearing liquid cooled center section. Pretty inexpensive turbo really, and I got a great price on it. I can't post who it came from, but if you want to know PM me.
Old 05-27-2013, 07:14 PM   #9
FrankT
FrankT's Avatar
The shop was Ultimate Performance and Racing in Fort Myers, FL. The next time they go in the ocean, I hope they get eaten by sharks.
Old 05-27-2013, 08:01 PM   #10
caper
Drives: 2010 IOM 2ss/RS
hey frank...your current fleet is damn awesome!!!! man I am jealous...good for you to have such bad ass cars.
caper is offline   Reply With Quote
Old 05-28-2013, 10:37 AM   #11
FrankT
FrankT's Avatar
Thanks!
Old 05-28-2013, 10:39 AM   #12
FrankT
FrankT's Avatar
I'm waiting on some adapters for the liquid cooled center housing to get here before I can finish everything up. The Turbonetics has 16mm fittings while the no-name turbo had 3/8 pipe. I'm also routing the cooling lines to the heater hoses. They were hooked up between the coolant vent pipe on the front of the intake manifold and the radiator neck at the cap. I don't think that provides adequate flow, so that is why I am changing it.
Old 05-28-2013, 12:24 PM   #13
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
The difference between buying a higher quality item at a higher price and a lower quality item at a lower price?
The people who buy the higher priced item only complain once, at the till.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 05-28-2013, 12:37 PM   #14
FrankT
FrankT's Avatar
It's not that I wanted a cheap turbo, like I stated I thought I was getting quality stuff. This just shows what a poor shop will do to you. There are far too many examples of this on the forum. However, I know I'm getting good quality with Turbonetics. BTW, almost everything this shop did has had to be redone. I probably should have pulled everything off and started over, but I wanted to make this work. I'm hard headed that way.
