HeadlightArmor
Old 05-26-2013, 07:38 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Royal purple vs mobile 1 extended performance?
Is royal really worth the extra penny?
If so, is there any way to get it cheaper then what im seeing at pepboys? $9.99 a quart
Nighthawk89 is offline   Reply With Quote
Old 05-26-2013, 07:39 PM   #2
mikeyg36
Drives: 2015 Z/28 #533
If I was spending that much money for oil, I would go amsoil. Royal is sketchy IMO. Mobil isn't what it used to be, but it's not awful.
mikeyg36 is offline   Reply With Quote
Old 05-26-2013, 07:46 PM   #3
matt55
matt55's Avatar
Drives: CTS-V
Of the two m1 ep, my money = pennzoil platinum/platinum plus or a amsoil dominator/sso
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 05-26-2013, 07:54 PM   #4
Nighthawk89
Amsoil "dominator" is the version made by amsoil?
Old 05-26-2013, 07:56 PM   #5
matt55
matt55's Avatar
Drives: CTS-V
Yes high zddp
Do some digging/searching at bitog forum (oil forum) oil geek heaven .
Old 05-26-2013, 08:48 PM   #6
hamp
Drives: 2010 SS/RS ;2012 & 2017 ZL1
Muscle Cars
I use Amsoil in all my cars except the Challenger. The only reason I use Moblie 1 in it Amsoil don't offer 0W-40 for it.
hamp is offline   Reply With Quote
Old 05-26-2013, 08:56 PM   #7
ramairetransam
Internet Car Tech
Drives: 99 formula
you sob . jealous .
ramairetransam is offline   Reply With Quote
Old 05-26-2013, 09:45 PM   #8
Mydivorcegift
GPI Built
Mydivorcegift's Avatar
Drives: 2011, 2SS/RS, Synergy
Joe Gibbs is my oil of choice.
GPI Built 416.
513rwhp/488rwtq
Track times coming to back it up.
Mydivorcegift is offline   Reply With Quote
Old 05-26-2013, 09:51 PM   #9
KlugSS
Guest
Posts: n/a
I buy my royal purple hps off amazon for 8 dollars a quart.
Old 05-26-2013, 10:18 PM   #10
Nighthawk89
Its legit too? Im thinking about buying a gallon of either royal or amsoil
Old 05-26-2013, 10:22 PM   #11
KlugSS
Guest
Posts: n/a
Yup, if you are a prime member you can have it 2 day shipped for free.
Old 05-26-2013, 11:13 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Amsoil and vr1 here. Sorry I won't do either.
Old 05-26-2013, 11:28 PM   #13
Denis
Denis's Avatar
Drives: 2010 SS
I either use RP or Mobile 1. Whatever is cheaper at the time. But I move out to MD my buddy has a hook up on amsoil. So ill be switching to that.
Old 05-26-2013, 11:59 PM   #14
SPCBA
Drives: pleather and Chiclets
royal purple does make a true synthetic with high anti wear additives. They also make a filtered dyno with synthetic additives and market it as a synthetic. FYI mobil one is not a synthetic, but if you are under warranty and the dealership sees a purple dyed oil they can void your powertrain warranty.
i have used gibbs and amsoil under extreme conditions. I was really happy with amsoil z-rod but I dont know if i can recommend it for non cammed cars. I am going to run amsoil domintor for my next track day on the first. It is red and I was unhappy about that but it is high in antiwear (not as high as zrod) but has a higher shear rating. I also cant say i recommend this for non track situations. these high in antiwear material oils also kill your cats fyi.
It all depends on how long you want to keep the car. Also how hard you are on it. A good oil WILL lengthen the life of the various fluid taking components of your drivetrain.
If you need a lower cost brand litle has said vr1 and he is right. I wouldnt run that in a modified car or on the track.
inform yourself and choose goodluck
SPCBA is offline   Reply With Quote
