sjm autoprod
Old 05-26-2013, 08:41 PM   #1
yellowrs
Drives: 2010 SS 426 V8 M/T
Disappointed with amount of dust from K&N CAI
So I just installed my K&N Typhoon CAI a few days and already I am annoyed with the amount of dust in my engine compartment.
I also do not like the sound nor can I feel the difference in increased horse power either.
I am surprised not more members are unhappy with their K & N purchase?
yellowrs is offline   Reply With Quote
Old 05-26-2013, 09:17 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Your thinking the k&n is causing the dust?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 05-26-2013, 09:47 PM   #3
yellowrs
Yes, I never had that amount of dust in the engine compartment with my stock air intake.
Old 05-26-2013, 09:51 PM   #4
Liam
Tampa Bay Camaros
Liam's Avatar
Drives: 2016 Camaro 2SS, Hyper Blue
1) The sound will be approximately the same from most intakes. They will always have that "growl".
2) The dust will also be the same with any intake, but should be mostly within the box. If there is a lot of dust outside the box, check the rubber seal around the top of the box to make sure it is meeting snug with the hood.
3) As far as the brand/performance...yeah all the other well known brands are much better in performance.
Liam is offline   Reply With Quote
Old 05-26-2013, 09:57 PM   #5
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Hey now! Consider a CAI brand next time.
I wonder if more dust is showing up because the airflow under the hood changed due to removing the stock airbox.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-26-2013, 09:58 PM   #6
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
The cai wont cause that. It can't make dust come in.
Your seals may have been misaligned during the cai install.
There aren't many complaints because most people don't get K&N as there are better cai out there. There is a thread w/ dyno numbers that show k&n doing little in increasing HP and TQ.
As mentioned above, all CAIs have that darth vader
Suction sound.
TastyBake is offline   Reply With Quote
Old 05-26-2013, 10:20 PM   #7
SS785
SS785's Avatar
Drives: Camaro SS
Most cone style CAIs have that suction-type sound. It's what they do. Vararam-style intakes have more of a growl sound (No hiss).
On the other hand, did you disconnect the battery and made sure that the tube was correctly aligned? K&N is kinda cheap so it doesn't line up as easily as other intakes, just double check the alignment and make sure it's straight. If everything is right, you should feel a difference man. If all fails, you can try a different brand but just for reference, I switched to a CAI and while it fits a lot better, it doesn't drive/feel any better in the street than the K&N.
Good luck, hope you can pinpoint the issue.
SS785 is offline   Reply With Quote
Old 05-26-2013, 10:42 PM   #8
Chat01
Drives: 2013 2SS/RS L99
I installed my K&N Typhoon a few weeks ago. I've had no dust/dirty issues under the hood that I can tell
I did the fuse pull for $h1ts and giggles after the install, not sure if I had to or not. As for the sound I think it sounds pretty good when you get on it. I've had K&Ns on my other vehicles with no issues. Never expected my car to be a much bigger beast with one on there either.
Chat01 is offline   Reply With Quote
Old 05-26-2013, 11:14 PM   #9
yellowrs
John B.
Hi John,
As you know I do a lot of driving on the freeway now. I never had that much dirt inside before.
The $ 145 extra for the CAI brand seems well worth it.
Will keep you posted.
Old 05-26-2013, 11:17 PM   #10
yellowrs
Yeah, everything looked good.
I guess living in the desert does not help either.
Anyway I just went back to OEM.
Will give the CAI brand a try.
By looking at the picture it seems it will contain they amount of airflow within the box.
Thanks
Old 05-26-2013, 11:35 PM   #11
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Had mine for over 3 years w/o issues nor complaints. The Typhoon works/looks great on my ride. Do you drive alot of gravel roads?
Old 05-26-2013, 11:56 PM   #12
yellowrs
Phoenix AZ is just like a gravel road.
You need to dust your house at least once a week.
I am sure the K & N works much better in colder and more humid places.
Anyway too much dust for me.
Old 05-27-2013, 12:10 AM   #13
King Nothing
Under a Freightliner
Drives: Sentra, Durango and Camaro
sorry for your purchase but they did start out for dirtbikes so for dirt and dust they are normally good lol side note, i did testing on my 2000 camaro at the track with a fram filter vs k&n, no difference at all.
i agree with tasty on the seals might be misaligned though. stick with stock
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
LQ build, 243 heads and LS6 intake
King Nothing is offline   Reply With Quote
Old 05-27-2013, 03:38 AM   #14
markas214
markas214's Avatar
Drives: 2012 2SS/RS L99 SIM convertible
I wonder how much dust a scoop would pull in here in Az.
markas214 is offline   Reply With Quote
