Old 06-29-2009, 11:52 AM   #15
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Originally Posted by bluecamaroguy View Post
Not that I would ruin the tires but is it possible to burn out and smoke the tires in the v6 auto? Or is the v6 too weak?
I was playing with mine yesterday. With the V6, the only way you can get the tires to turn from a standing start is if the conditions are just right. (Moon in the right phase, etc.) LOL
But...in "M" with traction control off and playing with the brakes just right, you can get the tires to turn. Keep in mind that it is a very fine line between the rear "pushing" you forward and not getting the rear tires to turn. I did it once, realized it was possible, then stopped because I really do not want to wear out the 20's any sooner than I have to.
Keep playing guys and you'll find the magic combination. In short...yes it is possible to do. Do it too much and you're going to need money on hand for new tires.
Keep in mind also that the Pirelli's are sticky tires too.
Hope this helps!
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 06-29-2009, 12:05 PM   #16
Big Thunder Performance
Drives: 2010 Camaro
Turn off the traction control, have a slight drag on the breaks and put it to the floor. It will smoke the tires all day long.
I have done it many times to show the V8 tools this car has power. I got down played again this weekend for having a V6 but no one wants to line them up.
2010 Camaro V6 best ET 14.64 @ 96mph
71 Olds Cutlass 440 cid Batten Small Block
74 Hurst Olds 640 cid Olds Big Chief Procharger Power
Big Thunder Performance is offline   Reply With Quote
Old 06-29-2009, 02:01 PM   #17
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Originally Posted by theholycow View Post
You mean, your 108hp lightweight FWD lame-tire Hyundai?
(I'm not saying that the V6 auto Camaro could or could not burn rubber, just that it's a tough comparison because the Camaro's got added traction to match its added power.)
V6 auto has open differential, so a one-wheel peel ought to be easy with all that torque as long as you know how to fully turn off traction control.
Heh - at 92,xxx miles you think I'm still on the stock wheels? Heh - and I'm not the kind of owner to buy the cheapest rubber. I buy the best I can get for the size (which I admit still isn't a pirelli, but still).
No, actually I think most of the difference comes from the fact that I have a stick - and being able to control the clutch makes spinning the tires a LOT easier.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 06-29-2009, 02:07 PM   #18
Nostromo
Drives: '11 DTS, '11 Yuk' Denali
Do that often enough and you could experience the phenomena of tread separation at high-speed. Too costly all the way around. Be safe. The parts on today's vehicles, all manufacturers included, are supplied by the lowest bidder, generally speaking.
Nostromo is offline   Reply With Quote
Old 06-29-2009, 02:09 PM   #19
Xanthos
PWA Relapse
Xanthos's Avatar
Thats why when I get my car, I'll be tracking down a really cheap set of wheels that will fit and some cheap tires for my "burnout rims."
Still going back and forth between a stripper 1LS and a 1LT with C&C - if I get the 1LS I'll be buying a set of 1LT wheels (and probably widening them so I can put 275s all around) and using the steelies to burn rubber.
- X
Old 06-29-2009, 04:00 PM   #20
marcajrfan
Drives: 2012 crt lt 1 rs,silver stripes
shut off the traction control and you can burn all the rubber you want!
marcajrfan is offline   Reply With Quote
Old 06-29-2009, 04:02 PM   #21
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Myself personally I don't plan on smoking the tires. If you get the RS package with the P-Zero tires they are about $450 each to replace. And from the tire codes the wear isn't very good on them.
Old 06-29-2009, 04:56 PM   #22
kutch720
kutch720's Avatar
Drives: Camaro 1LT RS
Yes you can do a lay a patch of rubber down with the V6. I had mine a few days and said the hell with it. Took the traction control off and burned out. I didn't even have the pedal all the way to the floor. Then got home and realized that I am not able to rotate tires and figured I am not doing that anymore.
kutch720 is offline   Reply With Quote
Old 06-29-2009, 06:57 PM   #23
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Yes your comments are taken into consideration because we all learn from it but when a hundred of you keep repeating the same thing and you do not even have the new Camaro can you please stop it. Yes you could do it on other models and makes but with what GM did on the LS/LTs (Automatics) it is very hard to do. They're made to take off fast with minimum to none spinning of tires. IMO.
RickRay is offline   Reply With Quote
Old 06-29-2009, 07:06 PM   #24
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
FIrst question... why in the h3ll burn some expensive tires?
2nd question.. isn't it better to have traction then no traction? I mean it makes since to have traction...
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 06-29-2009, 07:15 PM   #25
Fire
Drives: 1999 Firebird Formula
Originally Posted by Supermans View Post
An automatic V6 will have a harder time burning the tires than an auto.. its the traction control and torque management that will give you the most trouble..Turn it off and it will make your life a lot easier.
An auto will have a harder time burning the tires than an auto?
Fire is offline   Reply With Quote
Old 06-29-2009, 07:28 PM   #26
DCJ
DCJ's Avatar
Drives: 2011 Camaro 2SS RS
I am quite certain I could burn the V6 easily.....but am quite certain I never will. Even when my V8 gets here, I won't burn them either. I get on my V6 on the time but I don't won't to burn them. Man, I never realized how high these tires were. Heck I thought my Yukon tires were expensive lol
My other hobby or should I say sickness in addition to my 2011 SIM 2SS RS Camaro
DCJ is offline   Reply With Quote
Old 06-29-2009, 08:01 PM   #27
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Ah. They way you presented it, one would not expect stock tires on a 108hp Hyundai.
That would definitely make a big difference. The V6 manual Camaro can probably lay 100 yards of stripe...
My 170hp manual VW can probably burn off tires all day long. If traction control is off I don't even have to take off hard to burn rubber.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 06-29-2009, 08:32 PM   #28
jdbaker82
Banned
Drives: None
My friend used to do burn outs in his tic tac looking geo metro 10 years ago
jdbaker82 is offline   Reply With Quote
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 06:27 PM
about all-season tires sting39 Wheels and Tires Talk Sponsored by The Tire Rack 42 01-25-2009 06:37 PM
how much will it cost to make both tires burn bigrich2021 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 11 12-09-2008 09:40 PM
