Emblempros
Old 05-26-2013, 09:54 PM   #1
drayco513
drayco513's Avatar
Drives: ss2/rs
how much vacuum
i run the lg g6x3 cam , i never heard or checked until today what these cars make . checked mine from the line that connects to the c.a.i. (off the pass head) it made about 6". then from the evap from the drivers side of the intake manifold , right behind the tb. it made around 12" . is that what u guys are seeing. i know some cams will change things. but just wondering need a good data base for future guys looking. 950 idle also.
461/423 n/a
drayco513 is offline   Reply With Quote
Old 05-27-2013, 11:21 AM   #2
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
The LG isn't on here, but you can probably get an idea depending on the overlap. The pressures are in kPa units, you will need to convert inches to kPa.
http://www.gmhightechperformance.com...n/viewall.html
EDIT: ... and if you need to calculate overlap, use this: http://www.wallaceracing.com/overlap-calc.php
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 05-27-2013, 12:38 PM   #3
drayco513
drayco513's Avatar
Drives: ss2/rs
kk thats good find. from wht i found converting im around 45 or so @950 rpm. the lg is on a 111 lsa from my findings
461/423 n/a
Old 05-27-2013, 12:44 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
+3 so it's a 108 iirc
