Caryle Racing
Old 05-27-2013, 12:39 AM   #1
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
Coilovers going in - got questions.
So my Pedders XA coilovers are getting installed this week (Pace car package). I'll need to measure, but I am pretty sure the front of my car sits higher than the rear right now. I want to be as aggressive as I can with the stance and level it off. I anticipate 1.5 -1.75 of drop. I'm running Forgelines with Nineball's offsets, 275 up front and 315s in the rear. Anyone see an issue with that?
Right now it seems to me the stock ride was a little more "bounce" in the rear than the front. I'd like to tame that. What settings are recommended on the coilovers to maintain stock ride feeling (or slightly stiffer if need be) while still dialing up the performance?
Any other thoughts, comments, or things you'd do different if you were doing it all over?
IPT is offline   Reply With Quote
Old 05-27-2013, 01:06 AM   #2
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
BigBlock69RS is offline   Reply With Quote
Old 05-27-2013, 12:21 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Good luck. Not knocking the Pedders XA's, but I couldn't get mine dialed in no matter what setting I tried.
There was either too much bounce or the ride was overly firm and squirrelly. During aggressive driving (road course) my car never felt planted. And yes, I had the bushings timed and alignment done twice by a skilled performance shop just to be sure that wasn't the issue.
I eventually put the stock suspension back on my car.
I'm now looking for a more easily tuned coilover setup. I've heard Pedders supercar coilovers offer a better ride and more control.
The basic Pedders XA just didn't offer the control or ride quality I was looking for.
Old 05-27-2013, 05:07 PM   #4
IPT
Man, I hope I have a better experience than that. Truth is I think it rides pretty good stock. I just want to take it up a notch improving the performance and get her dropped.
Man I will not be happy if I spend all that money on the install, and then have to pay it again to go back to stock . I know I could recoupe on the coliovers, but not the labor - nor the frustration. I assume you contacted Pedders about your disatisfaction? Pete has been great helping me out thus far - I have no complaints about that.
Old 05-27-2013, 05:14 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Depending how the roads are where you live (pot holes, etc.) you may not want to drop the front 1.75". It's also good to remember that the rear cradle bushings will raise the rear end just a hair.
I have mine set at 14/16 for daily driving.
Click to view my build thread
Old 05-27-2013, 11:04 PM   #6
L99CAMA2011
L99CAMA2011's Avatar
Originally Posted by BigBlock69RS View Post
Got an extra bag bro we need some.
Old 05-27-2013, 11:08 PM   #7
L99CAMA2011
Coilover valving depends on other things like tire size, pressure , road condition and what the user finds comfortable.
Old 05-27-2013, 11:13 PM   #8
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
20-17 for track days and 10-12 for street..is what I like
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 05-27-2013, 11:16 PM   #9
The Stig
The Stig's Avatar
Very good point.
Old 05-27-2013, 11:40 PM   #10
L99CAMA2011
Very good point.
My front coilover setting didn't go so well with the stock 20x8s with Pirellis but the 19x9.5" and 275-40-19s Hankook V12 evos inflated to 42psi is the bees knees LOL. Side wall of these Hankooks is too soft but the center tire section is firmer than the stock Pirellis. The overall result is a well balanced, neutral cornering feel and firm not harsh like the Pirellis feel over bumps. So the car stays flat but still compliant over severe bumps.
Old 05-28-2013, 02:01 AM   #11
IPT
So I was searching posts and Pete had recommended 16 off full hard front, and 8 off full hard rear. Seems like there has been some confusion about the numbers regarding counting up from softest, or down from hardest. What are you guys doing? The range is 30 (hardest) to 0 softest?
Okay - just found this also from Pete - LOL, so now I don't know where to start ...
Highlights from the 160086 Instructions
Rear Coil Pre-Load 10mm
Adjustment Starting Setting from Full Soft
Comfort Front 6 Rear 3
Street Sport Front 12 Rear 6
Sport Front 15 Rear 18
Road Course Front 18 Rear 28
Drag Front 3 Rear 16
Old 05-28-2013, 07:15 AM   #12
The Stig
The Stig's Avatar
30 is full hard.
Old 05-28-2013, 08:29 AM   #13
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
I've got basically the same size and tire setup that L99cama2011 does and I've been running 12 front 10 rear on the street, and 20 front 14 rear on the track but now that I've seen what IPT posted about Pete's recommendations I'm a bit mystified about his road course settings. Are you sure he recommended 18 front and 28 rear? It wasn't the other way around; 28 front and 18 rear??
Do you have the link for his recommendations?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 05-28-2013, 10:27 AM   #14
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I know that pedders reccomends 10mm's of preload but I think that is way too much and it reduces the effectivness of the dampening. The result is an uncontrolably bouncing ride or a very stiff ride because you have to max out the dampers to the point where they are no longer allowing enough rebound and compression.
... and yes I am aware you need to time the factory bushings after you change the ride height.
jeremywes is offline   Reply With Quote
