Jason 98 TA
Old 05-28-2013, 10:52 AM   #15
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
The issue of XA settings came up in the latest GM High Tech Magazine.
GM High Tech Mag put Pedders XA coilovers and Nitto NT05R tires on their shop car and it ran slower (on average) than it did stock around the road course. They admitted they needed more time to try to dial in the coilover settings. But the fact that the car felt unstable and ran slower than stock proves a major point. You can't just throw XA coils on your car and expect it to perform better than stock.
I really don't think the basic XA coils are the best setup for a serious racer. They'll will work fine for someone wanting to lower their vehicle for daily driving, but I'd invest in something else if you're really into road course type racing.
Old 05-28-2013, 11:58 AM   #16
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
Originally Posted by jeremywes View Post
I know that pedders reccomends 10mm's of preload but I think that is way too much and it reduces the effectivness of the dampening. The result is an uncontrolably bouncing ride or a very stiff ride because you have to max out the dampers to the point where they are no longer allowing enough rebound and compression.
... and yes I am aware you need to time the factory bushings after you change the ride height.
What did you go with for your preload?
amanc96 is offline   Reply With Quote
Old 05-28-2013, 12:52 PM   #17
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
Originally Posted by Doc View Post
I've got basically the same size and tire setup that L99cama2011 does and I've been running 12 front 10 rear on the street, and 20 front 14 rear on the track but now that I've seen what IPT posted about Pete's recommendations I'm a bit mystified about his road course settings. Are you sure he recommended 18 front and 28 rear? It wasn't the other way around; 28 front and 18 rear??
Do you have the link for his recommendations?
Man, I looked at so many I'm not sure exactly what thread it was grabbed that from. I'll take a look after work and see if I can find it again.
IPT is offline   Reply With Quote
Old 05-28-2013, 02:03 PM   #18
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I used zero preload (the first point that does not allow vertical movement in the spring) with pedders XA 2.5" springs on Megan racing coil overs.
jeremywes is offline   Reply With Quote
Old 05-28-2013, 02:33 PM   #19
The Stig
knows 2 facts about ducks
The Stig's Avatar
Is it possible to change preload without removing the coil over?
Click to view my build thread
Old 05-28-2013, 05:53 PM   #20
jeremywes
jeremywes's Avatar
Yes absolutely! The preload is adjusted by the two lower nuts below the spring base and the ride height is adjusted by screwing the whole damper cartridge up and down in the strut housing.
You can even experiment with track specific settings by loading one side. Or front and rear balance to match track rotation etc. there are some really good books on the subject like "speed secrets"
Old 05-28-2013, 09:38 PM   #21
L99CAMA2011
L99CAMA2011's Avatar
Neutral or oversteer keep the rear setting stiffer than the front, if you want to add in understeer then bringing the front setting closer to the rear is the answer. The range of adjustments is wide as J Lo $#$$%#%. My Eibachs suck but handle great and has a huge range of ERS or Hyperco springs to make my car handle how I want. Also remember that you can use tire pressure to further alter the balance or even make the ride more compliant.
Old 05-28-2013, 09:47 PM   #22
L99CAMA2011
Ha Ha Ha. Actually it goes deeper than that. Pedders XA are not bad at all. Here is the thing and it is why I just bought the Pirelli 295-35-20 a few days ago to replace the Nitto NT05. Nitto NT05 are really you get what you pay for tire and is W rated(168mph). I had to pump the Nittos to 48 psi in order to match the Pirellis 36 psi. You can't put stiff coilovers on a car and then put soft sidewall tires on the car and expect the car to perform well. My car now with the stiff Eibach R1 are no longer the weak point like the stock suspension, the Nitto NT-05s are. For drag racing good tire, for road course on a 3800lb car with stiff is heck coilover setting not good. If you are running stiff track like coilover settings you also need a tire that can handle the pressure because as the suspension gets stiffer the tire becomes the weak point , that's why the car GM used handled worse than stock but if they had put a DOT rated tire on the car like a Hoosier brand tire then the results would've slaughtered the stock time. This is the exact same issue I am now having and is why my front Hankook tires are on their way off my front rims as well as the Nitto NTO5s. Michelin Super Sports are on their way in.
Old 05-28-2013, 10:08 PM   #23
sting808
Drives: 2010 SS RS
NT05 and NT05Rs are different. R's are for drag with soft sidewalls.
You'd think the reviewers would know that. Not to say the NT05 is all that... But good bargain for autoX.
sting808 is offline   Reply With Quote
Old 05-29-2013, 01:10 AM   #24
L99CAMA2011
Yup NT05Rs are softer. I still think NT05 street are still too soft as well, that's why I am taking them off.
Old 05-29-2013, 01:46 AM   #25
sting808
Drives: 2010 SS RS
I need to run them at 45 psi for autox. Looking at pilot SS, but now Rivals as next tire. Btw, running XAs at 14 and 10. Have stiffer springs due to FI weight up front.
Old 05-29-2013, 03:04 AM   #26
IPT
Doc - post # 22 from this thread: http://www.camaro5.com/forums/showthread.php?t=248324
Old 05-29-2013, 08:00 AM   #27
L99CAMA2011
Toyo has a Y rated 285-35-20. Tirerack.
Old 05-29-2013, 09:46 AM   #28
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Originally Posted by IPT View Post
Thanks! Don't know how I missed that thread. I wonder what sport he considers to be "sport front"... autocross? And is he recommending these settings with the stock sway bars or Pedder's sways?
Wish I had the time and access to a place where I could do some track tests to see what the different settings feel like.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
