Emblempros
Old 05-27-2013, 08:45 AM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
2012 Complete LFX engine core available
Any interest let me know. Cyls #2 & #4 have low compression 40 psi after a dyno pull and melted my spark plugs in those cylinders.
etmx183 is offline   Reply With Quote
Old 05-27-2013, 10:14 AM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Core?
Mods:
Old 05-27-2013, 12:29 PM   #3
etmx183
etmx183's Avatar
Not a ready to use item, needs to be rebuilt/reman.
Originally Posted by KaBoom1701 View Post
Core?
Old 05-27-2013, 01:23 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Is this the motor that let go down the strip or a different one?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 05-27-2013, 05:52 PM   #5
etmx183
etmx183's Avatar
This motor let go on a dyno run at a public event on a new nitrous setting.
Old 05-30-2013, 10:12 PM   #6
robmol1
robmol1's Avatar
Drives: 2012 Camaro 3.6L 2LT
Question
would you be willing to sell your cams?
robmol1 is offline   Reply With Quote
Old 05-30-2013, 10:19 PM   #7
SgtPickles69
Team LFX
SgtPickles69's Avatar
Drives: Fast
New nitrous setting??? What shot were you running?
SgtPickles69 is offline   Reply With Quote
Old 05-30-2013, 10:28 PM   #8
robmol1
robmol1's Avatar
Originally Posted by SC2150 View Post
Have stock cams if you need some....
what would you be seeling them for? beacuse i want to take them to a speed shop around my area to see what they can do for me about making custom cams for the LFX, unless they already have upgraded cams out there?
Old 05-30-2013, 10:32 PM   #9
SgtPickles69
Team LFX
Drives: Fast
They do. MACE cams!
Old 05-30-2013, 10:37 PM   #10
robmol1
robmol1's Avatar
Originally Posted by SgtPickles69 View Post
They do. MACE cams!
who and where to i order them from?
Old 05-31-2013, 02:39 AM   #11
etmx183
etmx183's Avatar
ENGINE IS NOW SOLD!!!
140HP setting.
Old 05-31-2013, 08:15 AM   #12
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
That stinks. I take it the bigger pills didn't go over so well?
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 05-31-2013, 12:03 PM   #13
robmol1
robmol1's Avatar
Cost to have custom grinds for these would be very high, and stock ones cant be reground as a pushrod style could so that wont help.
Best is to go with the proven cams already available. App 40 RWHP gains. Let us know if you want to do them. And, the 3.6DI is not any easy engine to disassemble and put back together properly..
So where do I buy them from and how much?
