Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
20,000 mile maintenance?
My car just hit 21,000 miles, and after completing an oil/filter change yesterday with Mobil 1 and a Wix filter, and draining my RX Catch can, I also cleaned my Vararam filter element, let dry overnight and re-oiled. My RX breather cap had a small amount of oil on it, so I soaked it in a cup of simplegreen/water mix for a couple hours, rinsed, and let dry overnight. The pollen is finally gone here in Central Arkansas, so I also covered the CAI with a trash bag and rinsed down the engine bay with simple green concentrate in my gilmour foam gun (also cleaned the gun in the process
![]() -infernoman2011 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
In cabin filter might be pretty nasty at this point (free to check and take a look)
Also would recommend a rear axle fluid change or inspection at least ours was very black with alot of metal on the magnets even at 700 miles
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98 |
![]() Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
+1 on the rear differential fluid. The cost of a quart of gear oil and some friction modifier is minimal. You spend more money on a movie and popcorn + drink.
![]() Drives: 2011 Silver Camaro SS Join Date: Feb 2012
I actually have a similar question:
I'm still under warranty and just hit the 21,000 miles mark. Is there any big/small service that requires me to bring the car in at this point? (my CEL is always on cause of midpipes so I can't tell) |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
You can go to Autozone or wherever (if you dont have a code scanner) and they can check if you have any other codes...
#6 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
I've been needing to change the differential. I'm at 28k.
#7 |
So, a great topic here with a very similar question: Just came from the dealership with my 2014 RS and it's first 21,000 and the guy tried to take $700 from me with 4 routine maintenance procedures.
Reading the comments here I've got some ideas, but which one are they? (I have no clue). Can I do them myself or do they need professional care? What is a fair price to pay? Anything you can share will bring light! Thank you!! |
#8 |
![]() Drives: 2011 Camaro 2LT/RS Join Date: May 2015
GM recommended maintenance schedule is in your owner's manual. Don't understand why it would cost $700 from what I see.
Thread Tools | |
