sjm autoprod
Old 05-27-2013, 11:55 AM   #1
Zdd
Drives: 2013 Camaro 2SS/1LE/RS
which engine oil did you guys use during break in?
About to reach the 300 mile mark on my car, which engine oils did u guys use or recommend to the 1500 mile mark and after?
Zdd is offline   Reply With Quote
Old 05-27-2013, 12:17 PM   #2
mikeyg36
Drives: 2015 Z/28 #533
Conventional is better than synthetic during break in because it will help remove any deposits/debris from the engine. After break in switch, to a full synthetic such as Amsoil.
mikeyg36 is offline   Reply With Quote
Old 05-27-2013, 01:38 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Seeing that he's brand new from the factory, he's already got synthetic in it now.
OP: If you're going to remain stock, or mostly stock for a little while, just use what GM recommends. In 2010 is was Mobil 1, not sure what they recommend now. As long as you use a good synthetic and use the same weight, you should be good to go. If you start adding a LOT of HP, you may consider switching to a specific brand for various reasons.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-27-2013, 01:57 PM   #4
SC2150
Full syn wont allow the rings to seat properly....I would drain and run a good conventional like mikey states, then at 1400 change to a good premium full syn. Not M1 as it is not as good as say Castrol Edge, or up to Amsoil for top grade.
I still stay clear of RP due to past bad experiances, but many have good luck w/it.
Old 05-27-2013, 02:03 PM   #5
Zdd
@ SC1250 Im already running the shell rotella u advised me just checking for the next steps what the other drivers have experienced.
Old 05-27-2013, 02:45 PM   #6
mikeyg36
Drain the synth and put in conventional. Synth is not good for a brand new engine.
Old 05-27-2013, 06:50 PM   #7
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
The car came new with Mobil 1
It says to use Mobil 1 on the filler cap.
? This is on a SS not sure on the six
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
