Jason 98 TA
Old 05-27-2013, 04:03 PM   #1
koolisdon2006
koolisdon2006's Avatar
Drives: 2012 Camaro 2SS L99 Victory Red
Resonator delete
So just bought the Flowmaster Outlaw Axle back system and was wondering while i have it getting installed this weekend at the shop should i do a resonator delete? And what would i need extra to get that done or can the shop make me a pipe? Also mine is the L99..Is it even worth doing?
koolisdon2006 is offline   Reply With Quote
Old 05-27-2013, 04:17 PM   #2
bw26ss
Banned
Drives: ss camaro
yes, it is a must in my opinion, Jegs and summit racing both sell one for $100 that work great, and it is a good idea to have them welded
bw26ss is offline   Reply With Quote
Old 05-27-2013, 04:20 PM   #3
km9v
Drives: 2011 Camaro SS/RS M6
Definitely worth doing. You can probably get a muffler shop to cut it out & replace it w/ straight pipe for fairly cheap.
km9v is offline   Reply With Quote
Old 05-27-2013, 04:21 PM   #4
bw26ss
Banned
Drives: ss camaro
I would def. use an x pipe instead of just strait piping it
Old 05-27-2013, 04:48 PM   #5
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
I have an LS3 but I'm 90% sure that I've read that the stock resonator on the L99 helps with your AFM 4 cylinder mode sound quite a bit. You might want to think about disabling AFM as well with the resonator delete.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 05-27-2013, 04:49 PM   #6
sub zero
sub zero's Avatar
Drives: RED@2SS
good idea with resonator delete , also if u gonna do straight pipe , all that job sure gonna be good if u plane to add headers and tune ur car .
if u want to keep ur waranty so , don't do it because u'll hear the AFM keck after delete the resonator
sub zero is offline   Reply With Quote
Old 05-27-2013, 04:50 PM   #7
koolisdon2006
Well don't want to void my warranty so was thinking of getting the Range V8 also what do you guys think if i did that?
Old 05-27-2013, 06:35 PM   #8
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
I have the range Afm delete ad also got a resonater delete. Sounds soo much better I recommend this route 100% cause I still have full warranty
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 05-27-2013, 06:41 PM   #9
koolisdon2006
Cool i'm gonna order the Range also and the x pipe tonight and Question for you jake2212 Seen you have a vmax ported throttle body does that could or will void my warranty?
Old 05-27-2013, 07:17 PM   #10
jake2212
jake2212's Avatar
I haven't gone in for warranty work on anything like that yet, but it's still a gm part so I would say no. Something small like that is up o the dealership
Old 05-27-2013, 07:21 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I got the Corsa LS3 cat-back (no resonator) and the range device. I love it!
Sent from my 2SS/RS
FSP tuned: 377/389
Old 05-27-2013, 07:39 PM   #12
craigk777
craigk777's Avatar
Drives: 2013 Summit White 2SS/RS
how much will the volume increase with the resonator delete???
craigk777 is offline   Reply With Quote
Old 05-27-2013, 09:01 PM   #13
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Not much, if at all...you'll hear more drone at highway speeds by simply removing them from a stock config.
Old 05-27-2013, 09:07 PM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Drone isn't taken care of with the resonators. That's a function of the factory J pipes.
Removing the resonator section is only beneficial for the weight savings and only on a L99. That section weighs in at around 15lbs. Ebay has a very nice 409SS X pipe that looks identical to the magnaflow True X pipe at half the price. You will have to weld in some extra pipe to make up for the length of the OEM resonator section.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
