ADM PERFORMANCE
Old 05-27-2013, 06:44 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
Hf cats vs. no cats
Ok so other than price is there any difference to the car (performence or sound) between the two?
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 05-27-2013, 06:46 PM   #2
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
Cats are a bit quieter and deeper. No cats are raspier, and make anywhere you go smell like a drag strip.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 05-27-2013, 06:47 PM   #3
jake2212
jake2212's Avatar
What's wrong with that? The drag strip always smells awesome!
Old 05-27-2013, 06:48 PM   #4
mikeyg36
mikeyg36's Avatar
I didn't say it was bad. I like it as well.
Old 05-27-2013, 06:52 PM   #5
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
No cats will add better power in combination with Long tube headers. With your mods, you might see up to 5hp gain. Plus without a tune you'll lose TQ down low and gain high in the band only.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 05-27-2013, 07:08 PM   #6
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Hi flow cats or green cats don't like boost. Boosted motors burn up cats . I too like the drag strip smell. No cats are free. I am a big fan of the cat delete. At least with my car, nothing raspy about it, matter of fact the exact opposite is true.
Mchlgrrsn is offline   Reply With Quote
Old 05-27-2013, 07:10 PM   #7
jake2212
jake2212's Avatar
Now if u get a cat delete the cel light turns on, does it effect any warranty work that might need done as well?
Old 05-27-2013, 07:17 PM   #8
mikeyg36
mikeyg36's Avatar
If you tune it it will void the warranty.
Old 05-27-2013, 07:18 PM   #9
jake2212
jake2212's Avatar
In trying to hold onto what little warranty I still have
Old 05-27-2013, 07:20 PM   #10
mikeyg36
mikeyg36's Avatar
If you want to have headers without having to tune, you would need green cats since they don't throw a CEL. Only problem is that Green Cats cost your right arm...
Old 05-27-2013, 07:21 PM   #11
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
You will most likely have a cel with hf cats and long tubes as well. That means it won't pass inspection(in most states). If you tune it it will void engine warranty. Double edged sword of modding the engine past cai and catback.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 05-27-2013, 07:21 PM   #12
jake2212
jake2212's Avatar
I'm just gettin hf cats, no headers
Old 05-27-2013, 07:23 PM   #13
mikeyg36
mikeyg36's Avatar
There's no point of just getting hi flows. It's not worth it.
Old 05-27-2013, 07:25 PM   #14
jake2212
jake2212's Avatar
Ok, was jw cause I plan on swapping my exhaust out for a zl1 exhaust and I wanna keep it loud
