Old 05-27-2013, 08:00 PM   #1
CBRpilot
CBRpilot's Avatar
Drives: 2012 SS
Welding aluminum/stainless to mild steel
The x pipe from HeartThrob Exhaust (http://www.mufflermonster.com/index....roduct_ID=2490) is "aluminized". Any clarification on whether or not it's actually aluminum? I know from previous experience on my 98 WS6 (aluminum oil pan) that welding aluminum to aluminum is hard to do...so I'd imagine aluminum to mild steel may be as well.
If I don't go with HeartThrob's x pipe, the other one is stainless steel. Any complications that you guys know of firsthand? Thanks for any help you're able to provide
CBRpilot is offline   Reply With Quote
Old 05-27-2013, 08:06 PM   #2
woolf
Drives: 2011 SLP SS
The heartthrob x pipe is aluminized mild steel not aluminum. Both aluminized and stainless will weld to mild steel with the proper weld rod.
2011 2SS/RS LS3 SIM
Hurst shifter. Lowered. SLP 575 Supercharger kit. SLP Loudmouth I. Maybe more to come?
http://youtube.com/watch?v=ezqXXgAnUus
woolf is offline   Reply With Quote
Old 05-27-2013, 08:08 PM   #3
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Just about every muffler shop in the country does it all the time.
Old 05-27-2013, 08:11 PM   #4
CBRpilot
CBRpilot's Avatar
Drives: 2012 SS
Good to know. While I'd prefer a better metal, at least the base metals match up. I'm not concerned about possible insulation loss around the welds, or the rust-preventative qualities of aluminum. I'll be painting the exhaust from the point of the new x-pipe down with hi-temp flat black coating. That's what my WS6 had on it's custom 3" exhaust for 8 years and looked brand new when I sold it.
Old 05-27-2013, 08:23 PM   #5
woolf
Drives: 2011 SLP SS
Pretty certain the stock exhaust is a 400 series stainless. In my opinion I'd get the stainless x pipe.
2011 2SS/RS LS3 SIM
Old 05-27-2013, 08:28 PM   #6
CBRpilot
CBRpilot's Avatar
Drives: 2012 SS
What would be the point of doing one small stainless section? If I were going full stainless, I see the point. But I'm not. It looks Magnaflow stamped flat sheet stainless and then seam and/or spot welded them together to make the x pipe. It may be fine, but it may also have a totally shit internal shape with unsmooth transitions.
Edit: I know Magnaflow makes a good product, but the term "stamped" is what has me worried.
Old 05-27-2013, 08:59 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The Magnaflow X pipe is cheaper than the heartthrob and is advertised as SS. Doesn't say what grade though. There are a few X pipes on Ebay that look exactly like the MF true X pipe for less than $40. One is 409SS and is around $35. That's the one i'd get if I had to do it over. I have the MF true X. If you have the L99, you'll have to weld in some tubing as well and if a muffler shop does it, it will most likely be aluminized.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-27-2013, 09:24 PM   #8
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
midas near me doesnt do anything in stainless, all their stuff is aluminized steel. for a good weld the aluminized coating should be grinded off.
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Old 05-27-2013, 11:21 PM   #9
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
What he was saying is that welding in the aluminized x-pipe, the x-pipe will be the ONLY section of your exhaust that WON'T be all stainless. Your current exhaust is already 100% stainless. And the way the Magnaflow is manufactured as a stamped piece, it actually has smoother transitions than a traditional x-pipe that is made from two pieces.
2012LS3VERT is offline   Reply With Quote
Old 05-28-2013, 09:33 AM   #10
woolf
Drives: 2011 SLP SS
Exactly
2011 2SS/RS LS3 SIM
Old 05-28-2013, 09:44 AM   #11
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
The aluminizing process is where steel is hot dip into an aluminum/silicon bath. The silicon promotes better adhesion. Here is a link. http://en.wikipedia.org/wiki/Aluminized_steel
RenegadeSS is offline   Reply With Quote
