BeckyD @ James Martin Chevy
Old 05-27-2013, 08:35 PM   #1
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
LS3 Engine Cover needed?
Is the LS3 engine cover strictly for aesthetic purposes or does it perform a function (to protect the coils??? ect).
Looking for facts not opinions on this one.
Thank you,
Matt
Old 05-27-2013, 08:42 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Not sure you are in the v6 section.
kjkjr27 is offline   Reply With Quote
Old 05-27-2013, 08:43 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Cosmetic purposes - and then the plenum cover has insulation on the underside for noise insulation.
Click to view my build thread
Old 05-27-2013, 09:29 PM   #4
Dropspeed
Dropspeed's Avatar
That is what I figured. Just didn't know if it served any other protective duties.
Nope, you are in the V8 LS3/ L99 Engine ect section.
Matt
Old 05-27-2013, 09:39 PM   #5
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
Does absolutely nothing except increase heat soak.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 05-27-2013, 11:16 PM   #6
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
It has a noise/heat insulator in there. Helps the engine warm up in the cold and masks the noisyness of a pushrod ls motor. I removed mine at delivery to keep the heat out.
snickerdoodle is offline   Reply With Quote
Old 05-27-2013, 11:45 PM   #7
Dropspeed
Dropspeed's Avatar
Thanks....I took mine off before I posted and looked it over. I saw the insulator and figured it was for noise reduction and thought the exact same thing: this thing is just a heat trap!
Old 05-28-2013, 03:09 AM   #8
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
LOL, no offense, but I think some of you guys are a teensy bit paranoid. I doubt that removing that small amount of fabric will have any significant impact on under hood temps especially after driving for more than 20 minutes. And you aren't driving with the hood open, lol!! And whatever heat you possibly are getting rid of, I doubt that will have any impact on performance. Take the cover off and the under hood temps are still gonna be unaffected...and that heat will still get to the engine...
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback - VTC!!
2017 Challenger Hellcat M6 - Legmaker CAI - MM ported TB - Sprint Booster!!
Saving the world...1 hp at a time!!
BlaqWhole is offline   Reply With Quote
Old 05-28-2013, 03:33 AM   #9
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
It's just cosmetic and may reduce a little engine noise. I took mine off and know of several others that have and have had no problems.
CHMSC is offline   Reply With Quote
Old 05-28-2013, 09:43 AM   #10
Dropspeed
Dropspeed's Avatar
If you look at data you would be surprised how little changes can have huge effects. Heat soak for normal driving is not an issue or the concern ...but for a drag racer heat soak can be a big problem as your car is sitting around waiting to make the next pass. For road racing it is also a concern as you come off the track and park the car. Any way to remove trapped hot air is a benefit.
-Matt
Old 05-28-2013, 10:59 AM   #11
BlaqWhole
BlaqWhole's Avatar
-Matt
I will agree with that. I did not know you were talking about strictly for racing purposes. I was mainly referring to daily driving. In which case I doubt it would have any affect.
Old 05-28-2013, 12:51 PM   #12
caverman
caverman's Avatar
Drives: '69 SS Convertible
I leave mine on for looks. Once I go to the drag strip I remove it to help get it to cool down a little quicker. I also removed the intake turtle shell as well for the same thing.
Build Journal
Old 05-28-2013, 12:56 PM   #13
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Here are my covers (engine and intake cover).
Both covers act like a blanket holding in heat.
Faster cool down with hood open and covers off at the track.
Old 05-28-2013, 08:25 PM   #14
maroman1138
maroman1138's Avatar
Drives: 2011 SS/RS LS3
I took both mine off as well, paint matched the intake and cut in the Hex Vents. Not a whole lot of heat trapped with this set up. Hell, I don't even use the rain trays that came with the Hex Vents.
2011 1SS/RS LS3 - Stage II Ported Heads, Stage II Comp Cam, Ported T.B., Hurst Shifter - 0BX LT Headers - CAT delete, Pype Bomb Axle-Back Exhaust - Muffler delete - 4.5 Resonated tips, Spectre CAI, - 480 RWHP 442 TRQ. Dyno tuned by ARD.
maroman1138 is offline   Reply With Quote
