2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
First Track Day in a 1LE (Bonus ZL1 too) LONG
First off....this will be long and detailed.
My background: I have been instructing for about 15 years with numerous clubs, last held a NASA comp license, and have had the opportunity to drive (hard) all sorts of street cars on different tracks including Lotus Elise, Exige, Evora, Esprit V8TT, 996 TT, C4s, Noble M400, Ferrari 599, BMW M6, M3, M5, Maserati Quottroporte Executive GT, Firebreather, Evo, Integra Type R, S2000, GT500, Dodge Minivan, Subaru Legacy and many more but you get the idea. However..the 1LE is the first V8 RWD car I have owned that I have tracked. Event was with 3Ballsracing.com at Grattan Raceway in Michigan. Grattan has seen many a magazine test and has seen many development miles from manufacturers here in Michigan as it is only about 2 hours from Detroit. My setup: 1LE picked up from Rodgers Chevrolet 1.5 weeks ago. I have just over 1000 miles on it. I had the oil changed, Motul 600 brake fluid added and dialed in the camber a hair. -1.3/-1.4 front and -0.08 / -0.09 in the rear. I pulled the fuse for the NPP exhaust for the noise and other than that it was all stock. Tire pressure was set at 32psi cold in the morning and away I went. I drove in both competitive mode and with everything off. Day started clear/sunny and in the 50s and climbed to high 60s in the afternoon. 1LE first impression: I really like the car as it is great out of the box. (DISCLAIMER: I am an aggressive driver so this car may be perfect for 80%+ of you to track it stock) The car is very fun to drive but shows it weight on acceleration and in the corners. It was "tossable" but had more body roll than expected. Acceleration was good...but I had a hard time at Grattan as 2nd was too low (too much RPM) and 3rd was too tall coming out of some of the corners (I ended up with 3rd gear as I had to "pedal" 2nd to control wheel spin). The tires were good and wear was even after 3, 20 minute sessions. Highs: Steering feel and turn in was great. The rear end would come around with throttle if asked It actually felt tossable as the transition from right, left, right set-up left through the esses was very good. Brakes are good and the stock pads worked well Transmission was flawless and engages nicely Car is stable at speed. 1LE will hit the claimed 1G according to the data I have. The motor did not use a drop of oil. Coolant temps and oil temps looked consistent all day. Owner of 2012 Z06 was very confused when SS Camaro caught him on the track and told his son the passenger (who told me) "Its only a Camaro....what is going on! after I passed him )Room for improvement: (for me) (NOTE: This is a great car out of the box for the $) Seats...even with cloth I was sliding around. Brakes: I want to add cooling ducts and a little more aggressive pad (long term will be 6 piston set-up) HP: I want more (who doesn't) Suspension: I might try some springs and maybe a rear bar to reduce body roll. Maybe coil overs down the road...but I want to see what springs and a bar would do AGAIN: this is my wish list...may not be needed by all Conclusion: The car does exactly what I paid for and what I expect for the price...What does that mean? It means it is good but not perfect (for me). This is a 3800+lb car with 426hp so it did very well given its heft. I like it a lot but will love it with a few tweeks. LAP TIMES: Numbers don't tell the complete story but my fastest lap was with traction off and in my third session out. I was braking early on the straight as I don't have a trusting relationship with these Brembos yet and I was still getting a feel for the car. With that said.... My fastest lap was a 1:31.47. So how does that stack up to other stock V8 RWD cars at Grattan? Pretty darn good for the price: 2012 ZL1 1:27.94 (Road and track) 2013 Mustang GT500 1:28.52 (Road and track) 2010 Corvette Grand Sport 1:30.2 (Car and Driver) 2013 Camaro 1LE 1:31.47 (Matt Jensen/me!) 2010 Mustang GT 500 1:33.3 (Car and Driver) There is also an Internet claim that Car and Driver ran both a Zl1 and a GT500 to a 1:30.2, but I can't find anything to verify that. I think there was a tad more in the car I could have rung out.....but I had to drive it to South Haven (1.5 hrs south, home of Gingerman Raceway) after to pick up the family and the ohhh so understanding wife would have been ohhhh so not happy had I broke it when it was 8 days old! Second issue....I was sick all morning and trying not to let on...Combination of lack of sleep, (I camped out at the track, it got down to 46 degrees so I moved to the car at 3:30am an slept in the passenger seat) bad choice of food, (Monster and a donut), bug or combo of all dumb choices above. I am not sure what did it, but I did throw up just before lunch and then Joe P from Rodgers bought some ice cream for me. I felt way better after that!! (for real) Thanks again Joe! ![]() So what makes a ZL1 3.53 seconds faster on this 2.2 mile road course? A couple of items like 6 pistons brakes, better suspension and about 154hp. Grattan has a 3200 foot long straightaway (see picture below) and the 1LE just does not have the HP to keep up with a ZL1 on that straight. Add to that the 6 pistons Brembos and the ZL1 can haul down the extra weight over and over again with little to no fade at the end of the straight unlike the 1LE. I had the chance to drive my students ZL1 who was none other than Becky D from Rodgers at her first track event ever.....(and she did very well!) The suspension was great in track mode (I believe setting 5) the brakes felt great and the power was more than enough to get in trouble. I am pretty sure Becky was hitting a higher top speed in her ZL1 than I could muster out of my 1LE even with my higher corner exit speed onto the straight....the ZL1 just has more go! According to the Motortrend test thje ZL1 hit 136 on the Grattan straight I was letting off at about 123 (according to data) as I was still unsure of the brakes. (I have hit 155MPH in my Evo race car back in the day on that stretch) So do I want a ZL1 over a 1LE? Yes as it is a great car, but No as I figure with a little suspension work, about 50whp and a set of CTS-V/ZL1 6-piston front brakes I could have just as much fun and be just as fast a a ZL1 on almost any track. So if you made it through all of that here are a couple pictures from the event along with some data log snap shots....I have video but was having issues with my editor so I gave up for tonight. There are also a ton more pictures that will be uploaded later. Another note: wash your car after a track day. (As you should) Even with the stock pads there was a bunch of brake dusk in the crevasse on the inside of the lip of our wheels. You need to get that area clean as it can stick to and damage the surface. The rear view mirror picture was taken on lunch time parade laps. That is Becky D and Joe from Rodgers Chevrolet in the white ZL1 and Mr. Wyndham (Joe) in his silver ZL1 who drove in from Buffalo NY for the event! The STIGWHO plate is not really mine...I good friend works for SVT and has the STIG plate on his Mustang so another friend got this plate for his Z06. It was on my car for a little fun. -Matt .
ROAD COURSE JUNKIE
Sounds like you had an awesome time!! Is that an app for your phone? If so what is it?
#3 | |
-Matt
ROAD COURSE JUNKIE
Thanks I will check it out.
![]() Drives: 1LE , 1SS , NPP Join Date: May 2013
Thank you for the info. A cheap way to make a little more HP and keep the stock valve train is to go with a LS9 cam . Form what I seen it should bump the motor about 20 HP from 4,000 to 6,600 RPM range . I am thinking that right were it would help most on the long straightway to help the car hang with the higher HP cars better .You can get the cam , sprocket and blots new GM parts for about $150.00. Now if you can do the labor your self it can work out as a cheap up grade . Here a link you can read where they put this cam in a GM 2011 truck made 50 more HP in the truck.
http://www.gmhightechperformance.com...shaft_swap/The LS3 in the Camaro will not pick up as much HP because the LS3 has a better cam to start with. Now I like to tell you the cam works out great but I can not because I can not get my darn car out the black hole of GM. The car is still Bayed but what you ran into was just what I was thinking was going to happen and I got the cam here waiting for the car to show up from the dealer. You may want to go with a adjustable sway bars front and rear . Its look were stuck with ZL1 bars for now http://www.phastekperformance.com/20...l1-1410138.htm . I be looking forward to your UP Grades and how they work out for you. |
#6 |
![]() Drives: 98 Camaro SS Join Date: Nov 2012
Very good write up. Thanks for posting.
98 Camaro SS M6, a few mods
13 Ram R/T, tow vehicle 6th gen?? |
#7 |
It's all hers.
Drives: 2015 ZL1 Join Date: Jan 2012
Good read!!!
#8 |
![]() Drives: 2003 Porsche 996tt Join Date: Sep 2011
Thanks for the review, I've been waiting for someone to post their impressions of the 1LE. I've been tracking a GT3 for the last couple of years and keep looking at the 1LE wondering if I would be happy with it, sounds like I may not be based your observations.
#9 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
sounds like a super fun day. The times were just icing on the cake!
#10 |
Do you even lift, bro?
interesting to read...wanna borrow my 1LE for a day? :P
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461 |
#11 |
Sellin Chevy's since '06
no sh*t! Matt I installed Eibach lowering springs,American Racing LTs, Vmax throttle body and K&N intake kit.
Round 1 of bolt-ons complete....I need you to drive it though Nice write up.
'24 CT5 Blkwng CF1&2 6spd manual Coastal Blue
SOLD!'23 CT5Blkwng manual Rift Metallic SOLD!'19 Z06-7Speed and lowered on stock bolts SOLD'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
Thanks for the write up and review Matt. Always nice to hear impressions from people that have driven many different types of cars.
Sounds like you had a pretty fun day...other than the not feeling so well part.
#13 |
Hey Matt,
Regarding your rear sway bar, from what I've heard from Pete at Pedders is if you put their 32mm ZL1 Rear bar on the 1LE it makes a nice improvement over the stock sway bar set up.
#14 |
Drives: 2013 1LE Join Date: Jan 2013
Great write up and nice to hear a fairly unbiased impression. I've had my car for about two weeks and I will be hitting NJMP Lightning, NHMS and Watkins Glenn beginning July the fourth weekend. June is going to be a long month.
What did you think of the stock tires? So far I'm having a very difficult time finding a true race brake pad. There is no application from Hawk, PFC, which is what I've used previously. PFC 01, or the blue HT 10. I'm aware that long tubes and a tune are typically the most bang for buck, but would getting a custom ECU tune without any bolt on upgrades have any significant gains? Last edited by Abdi; 05-28-2013 at 08:51 AM. Reason: Spelling |
