Old 05-28-2013, 12:33 PM   #1
weSS
weSS's Avatar
Drives: 2010 Camaro 2SS/RS
Question about Pfadt 1.25" lowered springs with large tires
So I might have gotten a little ahead of myself. Over the weekend I got new American Racing Torq Thrust M AR105M 20x10s 34mm offset (rear) paired with Nitto Invo 315s.
I've already ordered and paid for the Stage 2 ZL kit from Pfadt, planning to install later this week or early next.
Does anybody have experience with a similar setup that can help me out here? Will I see a true 1.25" drop? As you can see above it looks like I only have 1.5-2.0 inches before I'm dragging the tire.
weSS is offline   Reply With Quote
Old 05-28-2013, 01:15 PM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I'm suprised that you got 315's on a 20x10. Discount tire said they would only reccomend 305's. I thought I read some where that you could machine the wheels but that might just be urban myth. Try the same post in the wheel and tire forum and you might get some better ideas than mine.
jeremywes is offline   Reply With Quote
Old 05-28-2013, 04:53 PM   #3
weSS
weSS's Avatar
u/bestwheeldeals on here sells almost all of his wheel packages in a 20x10 with 315 variant, and I recall a thread where someone called him out and he pretty strongly stood behind it. Modica Brothers had no negative input on the subject. I did a good bit of research, seems the Nitto Invos run a little slim, and the results I see on the ground is very little to no noticable sidewall bulge.
Anyway thanks for the response. I believe my ground contact is very adequate, just concerned about the fenders rubbing the tires after I lower it. Hopefully someone here has run 315s on a similar offset with the Pfadt stage 2 kit, without issue...
Old 05-29-2013, 12:15 AM   #4
FRSTR90
FRSTR90's Avatar
Drives: 2010 Camaro 1SS/RS, 1973 Corvette
Might want to PM C5 member Denis. Im pretty sure he is running nurburgring 20 x 10 with 35mm offset and 315/35/20 INVOs for the rear. I believe he is also lowered on PFADT springs.
I'll be running those wheels in all 4 corners with 275 tires and the zl spec stage 2 from PFADT, but my tires will be a lot narrower than your set-up.
FRSTR90 is offline   Reply With Quote
Old 05-29-2013, 01:21 AM   #5
Denis
Denis's Avatar
Drives: 2010 SS
I'm running 20x10's and 315 Nitto Invo's and PFADT springs.
Old 05-29-2013, 01:25 AM   #6
FRSTR90
FRSTR90's Avatar
Denis, I haven't told you personally, but your car is one of my favorites here!
Old 05-29-2013, 01:32 AM   #7
Denis
Denis's Avatar
Drives: 2010 SS
Thanks man!
Old 05-29-2013, 01:33 AM   #8
Denis
Denis's Avatar
Drives: 2010 SS
Weird I didn't even see this!! Haha
Old 05-29-2013, 10:37 AM   #9
weSS
weSS's Avatar
Perfect, thanks Denis. It looks like your offset may be a little different, my wheels may stick out a hair farther, but it's hard to say. Looks great though.
Old 05-29-2013, 11:12 AM   #10
jeremywes
jeremywes's Avatar
You can always run a little more negative camber if ur too close for comfort
Old 05-29-2013, 11:29 AM   #11
Denis
Denis's Avatar
Drives: 2010 SS
im running a 35mm offset at all four corners. the fronts are 20x9 and rear is 20x10.
Old 05-29-2013, 12:36 PM   #12
weSS
weSS's Avatar
Perfect thanks again. Sounds like I'm good to go.
Old 05-29-2013, 03:53 PM   #13
Denis
Denis's Avatar
Drives: 2010 SS
Oh yea. You're good. Lets see some pics from farther back.
Old 05-29-2013, 04:39 PM   #14
weSS
weSS's Avatar
