Caryle Racing
Old 05-28-2013, 04:18 PM   #1
crazyduc996
Drives: 2011 Camaro SS convertible
1st-2nd-5th shifting resulting in a grind of reverse
I put a skip shift eliminator on last summer shortly after getting my camaro, I will usually do a hard pull in 1st and 2nd and then go straight to 5th, because by then I am easily at speed limit territory, however far too often it goes into reverse and grinds for a split second while I react.. have any of the rest of you experienced this or is this just unique to me... I fear the problem will get worse with the addition of my Hurst short throw... I will also add that I do not feel a reverse detente or anything blocking me from reverse...????
Mike
Thanks in advance
GM Hotcam, JBA shorties mated to JBA cat deletes, Solo Performance cat back with J-pipe, Roto-Fab intake
crazyduc996 is offline   Reply With Quote
Old 05-28-2013, 05:00 PM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Go into 6th gate for a split second then go to 5th. You can avoid the 5th gear miss. You are pushing too hard if you are hitting reverse. Yes I have done it myself.
