Old 05-28-2013, 09:00 PM   #1
Rabamaro
Drives: 2010 ABM SS/RS
3.91s at the track
Has anyone installed the 3.91s in their manual SS and gone to the strip? I'm curious as to how this mod affects ET and trap speeds.
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
Rabamaro is offline   Reply With Quote
Old 05-28-2013, 09:12 PM   #2
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
I'm gonna be running mine fathers day weekend at Camaros for Heroes.
Sent from my Apple sued Galaxy Note 2
stikSS is offline   Reply With Quote
Old 05-29-2013, 06:47 PM   #3
Rabamaro
Sweet. Let me know how it goes!
Old 05-29-2013, 07:25 PM   #4
NinoSS
Drives: 2SS/RS CGM LS3
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 05-29-2013, 08:20 PM   #5
Gary B
Gary B's Avatar
Drives: Subaru
I have been wanting an answer to this question for a long time! Seems the people that have put gear in there car, are not drag racers....
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
Gary B is offline   Reply With Quote
Old 05-30-2013, 03:35 AM   #6
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
you might want to post it here, I'm sure lots of guys racing have done gears: http://www.camaro5.com/forums/forumdisplay.php?f=46
IPT is offline   Reply With Quote
Old 05-30-2013, 07:56 AM   #7
2012REDSS
Drives: 2012 Camaro SS
ive had my car with the 3.91s at the track several times. The trap speeds are about the same but the launch takes a lil bit of getting used to. With the gears its easier to smoke the tires out of the hole if you dont slip the clutch just right. Also the extra shift sucks. I shift to 4th about 150ft or so before the line. I used to be right at redline in 3rd before the gears. Once I added the Vortech I was trapping 123 easing out of the hole to avoid roasting my clutch or snapping a half shaft. I'm not the best driver in the world so my launches and traps arent as good as most of the guys here.
2012REDSS is offline   Reply With Quote
Old 05-30-2013, 12:39 PM   #8
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
I did this early this year. Stock form I trapped consistent 111.02. After the gear swap to 3.91 I slowed down to 110.55 consistent. However my 1/8 mile time picked up by 2.5 mph and my overall 1/4 et picked up a solid 3 tenths.
This all happened with the same track conditions or as close to as possible.
Take it for what it's worth.
Cheers
BFASTNOTLAST is offline   Reply With Quote
Old 05-30-2013, 12:57 PM   #9
Rabamaro
Cheers
Great info. What else is done to your car? I'm shifting to 4th anyway and am wondering if shifting to 4th sooner with the 3.91s will help or hurt my trap speed.
Old 05-30-2013, 12:59 PM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
I pick up a little MPH at an 1/8th mile track but not much.
As far as street light to street light.....well worth adding the gears. Noticeable torque increase.
Build Journal
Old 05-30-2013, 05:28 PM   #11
BFASTNOTLAST
Drives: 2012 SS LS3
This was with the gear only. With the 3.45 I would finish the 1/4 just about hitting the limiter in 3rd and at 111mph. For shi#$'s and giggles I shifted to 4th a little early and my mph slowed down to 109.5mph. So now with the 3.91 I'm shifting 4th probably around the 1000ft mark and trapping mid 110's.
