B&M Racing
Old 05-29-2013, 09:17 AM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
BMR Toe ends and Trailing Arms
I already have BMR Springs and Sways. Using GM Strut tower Brace. Have BMR street bushings in the rear. I am now thinking of doing the Toe ends and Trailing arms. I dont do off road racing and will only hit the 1/4 mile once in a blue moon. My drive to work does have lots of turns that is why i did the springs and sways which made a huge difference.
My question is it necessary to buy the TCA 027 vs the lesser expensive TCA026
http://bmrsuspension.com/?page=produ...d=77&catid=227
and same question with the TR002 vs TR003
http://bmrsuspension.com/?page=produ...d=77&catid=226
My other Mods are in my signature.
thanks
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 05-29-2013, 11:33 AM   #2
EM1/SS
Drives: 11 2SS/RS M6 vert
I went with the lesser expensive ones. I've heard you may need the adjustable toe rod to get your alignment right if your dropped a lot. If your alignment is good with the stock toe rods, you should be good with the non-adjustable ones.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 05-29-2013, 12:07 PM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
thanks
I would recommend the TCA026 and TR002 out of the options you have listed because the other options would honestly be overkill and a waste of money for what you are doing. The one thing I would recommend doing with the trailing arms (TCA026) is the outer trailing arm bushings (BK006) because there is overlapping labor between the two parts and they work very well in conjunction with one another.
I also responded back to you PM!
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 05-29-2013, 12:50 PM   #4
IneedAZ
IneedAZ's Avatar
So, does the TCA026 not come with bushings? Is that why i need the BK006 too?
Old 05-29-2013, 05:10 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The TCA026 trailing arms do not come with the outer trailing arm bushings because they are not absolutely needed to install the trailing arms but they are something we definitely recommend.
Kyle
T.C. Davis
813-986-9302
