SDTW Custom Wheels & Tires
Old 05-29-2013, 08:42 AM   #1
jkof08
jkof08's Avatar
Drives: Black 2SS/RS
Should i take off the resinator
i have the flowmaster pro series axel back kit. it isnt very loud so i was considering doing a resinator delete on my L99. is this going to be too loud? should i do it? will there be an anoying drone? it is going to be 125 to get it done at a local shop.
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM)
jkof08 is offline   Reply With Quote
Old 05-29-2013, 08:44 AM   #2
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
I have headers, SOLO axle back, HF cats, and I DO NOT recommend taking out the resonator.
The car would be way too loud if you did that, with headers.
If you never get headers, then go for it.
You will need a tune, or a range device or AFM is gonna be nasty. Definitely need an X pipe or H pipe, in the same spot as the factroy one
Old 05-29-2013, 08:48 AM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I'm sure you're getting drone NOW, with those mufflers. As vroom posted, if you're going to remove the section, you'll need to put a aftermarket X or H pipe in it's place. The OEM H pipe is located within that section.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-29-2013, 09:08 AM   #4
jkof08
jkof08's Avatar
i have a diablo tuner and turned off the AFM and it doesnt have a drone anymore. and i plan on doing headers soon.
Old 05-29-2013, 11:06 AM   #5
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
If you take off the resonator and replace it with an h or x-pipe, it's going to be pretty darn loud especially with your Flowmasters.
I was running a Magnaflow cat-back, no resonator and no tune, and never really encountered any drone.
Old 05-29-2013, 01:53 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
If you plan on headers soon, I would wait and see how you like it after the headers are installed. Then decide if you want it louder. I'd recommend the Magnaflow Tru X pipe or the Resonated X pipe depending on how loud you want to go with it. Please feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 05-29-2013, 02:01 PM   #7
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
.....wait until you install your headers; then listen, then decide.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 05-30-2013, 02:27 PM   #8
scites
Drives: 2010 camaro SS/RS
I had mine cut out and replaced it with a X pipe. i also had the mufflers replaced with flowmaster 10 series race muffler..my wifes 2012 mustang was still louder..i installed HF cats and that made a hell of a difference..its about as loud as my wifes mustang, but with a better tone..im telling you removing the resinator dosent make it much louder at all..
scites is offline   Reply With Quote
Old 05-30-2013, 03:03 PM   #9
RJT-SS
RJT-SS's Avatar
Did removing your resonator change the tone? Did you do install your Flowmasters at the same time you installed your X pipe? I already have headers and cats and trying to decide whether to just go axle back or all the way with a cat back.
Performance Mods:
Old 05-30-2013, 09:46 PM   #10
scites
i did the axle back first, then it wasent loud enough so i had them replas the resinator with an x-pipe..make it a little loader, but not much. the xpipe changed the tome for the better, IMO. i still wanted it loader so i put on JBA high flow cats..now i love how it sounds.
Old 05-31-2013, 10:29 AM   #11
jkof08
jkof08's Avatar
awesome i will probably get them to take it off with some room to put it back on if it ever gets too loud.
Old 06-03-2013, 08:36 PM   #12
bloink2018
Drives: 2012 2ss camaro ibm
just got my res took off sat noticed they didnt x or h pipe it bummer i have gm performance mufflers it sounds awsome not to loud at all
bloink2018 is offline   Reply With Quote
