Old 05-29-2013, 10:48 AM   #1
vandervortadam
Drives: 2010 Camaro 2ss black 21's
Foam vs microfiber buffing pads for PC
Just wondering some pros and cons of both and how they work. Also what brand of pads and what
size is the most common used by eveyone here. I have adams 7" foam pads
and. But they seem to be to big to get the work done in a timely manner. Thanks
Posted from Camaro5.com App for Android
vandervortadam is offline   Reply With Quote
Old 05-29-2013, 10:55 AM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Go with 5.5" with either foam or microfiber.
I tend to agree with most that microfiber cuts better than foam, but does not leave the best finish.
For that reason, I compound with microfiber and polish with foam to get the best of both worlds so to speak.
Pros and Cons:
Microfiber needs to be cleaned once per panel. No ifs, ands, or buts. Foam can be cleaned a little less often.
Microfiber cuts more, but doesn't finish as well as foam.
You need only 2 microfiber cutting pads whereas 4 foam polishing pads.
About the same price.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 05-29-2013, 11:04 AM   #3
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
Good post by camaro above, when I want to heavy correct, like deep swirls, I use MF.....Coolwave foam CCS for everything else....
Glen e is online now   Reply With Quote
Old 05-29-2013, 12:41 PM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Only other thing I'd add is that MF is infinitely easier to clean. You can even toss them in the washing machine.
[B]
Old 05-29-2013, 05:17 PM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I'll expand on that by saying easier to clean when you're done using, but much more work to keep clean during use. MF performance is greatly impacted the more loaded up it gets and the more matted the fibers become.
