Old 05-29-2013, 02:43 PM   #1
r1coder
Evo MR to Camaro SS
r1coder's Avatar
Drives: 2012 45th SS LS3
Suspension Installation Suggestions
Hey all,
I'm looking for some advice on a good shop that can install my Pfadt Stage 3 ZL Spec Suspension Kit. (i.e. Sub-Frame bushings, Springs, Sways, trailing arms, alignment, etc...)
I am looking for someplace close to home (North Eastern PA or North Western NJ).
Does anybody have a good recommendation?
r1coder is offline   Reply With Quote
Old 05-29-2013, 08:05 PM   #2
r1coder
Evo MR to Camaro SS
r1coder's Avatar
Anyone?
Bueller?
Old 05-29-2013, 08:26 PM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Might get more hits if you post in the regional forums.
Old 05-29-2013, 09:29 PM   #4
SkunkJunk420
SkunkJunk420's Avatar
Drives: "The Skunkmobile"
do the springs, they sways, and the trailing arms yourself, save the money cause its super easy
SkunkJunk420 is offline   Reply With Quote
Old 05-29-2013, 09:42 PM   #5
r1coder
Evo MR to Camaro SS
r1coder's Avatar
That's what I was thinking but the sub-frame bushings without a lift... ouch!
Old 05-30-2013, 03:03 AM   #6
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Actually I thought the subframes were really easy too with jacks and jack stands. With a partner of course.
K32 Camaro is offline   Reply With Quote
Old 05-30-2013, 05:56 AM   #7
L99CAMA2011
L99CAMA2011's Avatar
wanna do mine?
Old 05-30-2013, 06:33 AM   #8
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
I did mine with just a jack and jack stands. No partner (wife was home just in case). With the car on jack stands, loosen one side of the subframe and take out the bolts on the other, supporting the subframe with the jack. heat the bushing mount area with a propane torch and using a socket as a press jack the subframe up, pushing the bushing out. This method was posted by Rob@wretchedmotorsports in another thread. The fronts came out very easy, the rears took a little more work because of their size. I never even had to take the stock exhaust off.
danvillekidd is offline   Reply With Quote
Old 05-30-2013, 06:54 AM   #9
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Maybe if you are doing the inserts. The full bush is a PITA to get out.
jeremywes is offline   Reply With Quote
Old 05-30-2013, 10:59 AM   #10
SPCBA
Drives: pleather and Chiclets
sawzall
SPCBA is offline   Reply With Quote
Old 05-31-2013, 07:04 AM   #11
jeremywes
jeremywes's Avatar
Originally Posted by SPCBA View Post
sawzall
Have you tried it? Maybe if you can get a hole saw to cut the ferrule out of the center otherwise
Here is how I did mine but I completely removed the rear subframe to make it easier.
http://www.camaro5.com/forums/showthread.php?t=289431
Old 05-31-2013, 07:18 AM   #12
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Sawsall works. I had mine done but we did my friends on jack stands in my garage. Annoying but not really hard.
mp51998 is offline   Reply With Quote
