HeadlightArmor
Old 05-29-2013, 08:32 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
easy low speed fan on/intercooler pump "on" jumper technique
Pictures do the talking but this is an extremely easy way to turn on the low speed fans and intercooler pump with the key off. You can place the jumpers and replace the relays if you want these to run continuously while the car is at the track. You could easily place the jumpers in the pits once you park the car. Use a 4" piece of 14-16 gauge wire and strip both ends for each jumper. Relays K 641(ic pump) and K 613(low speed fans). Check out the pics. Hope this helps!
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 05-29-2013, 08:34 PM   #2
Stephen12ZL1
Drives: '17 ZL1 A10
next pic of fusebox lid
Old 05-29-2013, 08:57 PM   #3
All-American ZL1
Chevy Power
All-American ZL1's Avatar
Drives: 13 ZL1 M6 #123, '98 Jeep Wrangler
I've been waiting to see this! I got a bit confused by the second sentence though. If I want them to run continuously whether the car is on or off do I place the jumpers and then place the relays on top of the jumpers??
2013 #123, M6 2.38 upper, ID850, dynatech 1 7/8 headers, cats, X pipe, ADM CAI, 160 Tstat, Hurst line lock, tune by FSP
Sebring 2:39.20 MPSS
All-American ZL1 is offline   Reply With Quote
Old 05-29-2013, 09:08 PM   #4
Stephen12ZL1
Drives: '17 ZL1 A10
the fans and ic pump will both run if you place the jumpers as pictured without the relays with the key off. The relays placed over the jumpers will keep the jumpers in place so they don't shift. So, if you placed a flat spade connector for each location and placed the jumpers you could leave the relays out if you want to run continuously while at the track. Just remember to replace with relays after your track runs.
Old 05-29-2013, 09:34 PM   #5
cam99
cam99's Avatar
Drives: 2012 ZL1
You are my freaking hero. Been wanting to do this. Awesome
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 05-29-2013, 09:39 PM   #6
All-American ZL1
Chevy Power
awesome I'll try this tomorrow night, its hot as hell in Florida already !
Old 05-29-2013, 09:53 PM   #7
Stephen12ZL1
Drives: '17 ZL1 A10
91 in VA today too!
Old 05-30-2013, 04:20 PM   #8
Stephen12ZL1
Drives: '17 ZL1 A10
do this only in the pit area with the relays removed and key off. Replace the relays or place the relays over the jumpers for a continuous "on". If the relays are not replaced when the key is turned on, you will get an open circuit "check engine" light.
Old 05-30-2013, 07:31 PM   #9
cam99
cam99's Avatar
Drives: 2012 ZL1
does the check engine light go back out once you put relay back in?
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 05-30-2013, 07:35 PM   #10
Stephen12ZL1
Drives: '17 ZL1 A10
it might if you disconnect the battery. I have a cheapo scan tool and cleared it.
Old 06-06-2013, 09:14 PM   #11
cam99
cam99's Avatar
Drives: 2012 ZL1
Just wanted to tell you I used these jumpers at the track this week and they work so good! Thanks again for the info!!
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 06-06-2013, 09:35 PM   #12
Stephen12ZL1
Drives: '17 ZL1 A10
Your awesome track times prove it! Over 120mph stock boost!
