BeckyD @ James Martin Chevy
Old 05-29-2013, 11:01 PM   #1
CamaroBlue
CamaroBlue's Avatar
Drives: IBM 2010 Camaro SS
Stock exhaust removal
I have searched this forum up and down but I can't seem to find a detailed DIY on removing the stock exhaust. Is there one or is this a fairly simple mod to make and a DIY isn't really necessary? I have never done anything like this but I'm handy with some tools. Any help would greatly be appreciated.
CamaroBlue is offline   Reply With Quote
Old 05-29-2013, 11:16 PM   #2
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
it is very easy.
1.jack car up, put on 6ton jack stands, there will be about 15" under the car.
2.remove tunnel brace (4 bolts)
3.unbolt band clamp directly behind cats.
lower the front of the exhaust, then work the muffler hangers, the whole thing comes out in one piece. It helps if you spray some wd40 on the rubber hangers.
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Old 05-29-2013, 11:24 PM   #3
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Originally Posted by black79ta View Post
it is very easy.
^^ THIS. It's very simple. The entire exhaust from the cats to the tailpipes is one solid piece. It's pretty heavy so be aware of that. The rear hangers can be a little bit of a pain due to location. It is also a good idea to disconnect the battery so that when you start it up the car will learn the new exhaust right off.
If you are planning entire exhaust. IE headers. Disconnect battery. Unhook the 4 02 sensors (1 in the back of each head held in place with green clips. & 2 underneath the car simply unplug), remove spark plugs (so you don't crack them) then unbolt your oil dipstick and pull whole tube up and out then unbolt stock manifolds and take them out from the bottom cats and all. Then remove your 02 sensors from the bungs. Use anti seize when installing into new setup. Buy new OEM exhaust manifold gaskets or possibly use your stock ones. Never use the crap that comes with new headers or any RTV. Do the passenger side first as it's the worst side. Getting the dipstick tube back in sucks for most people but, i got it first try. After they are on make sure to go back and check the bolts again after a few heat cycles.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 05-30-2013, 06:14 AM   #4
CamaroBlue
CamaroBlue's Avatar
Do I need to have the entire car lifted to put on a cat back exhaust. In not going headers yet.
Old 05-30-2013, 06:22 AM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I found this in 2 seconds. Come on man
http://www.planetlsx.com/tech/How_To...0_Camaro_SS/98
Old 05-30-2013, 06:26 AM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
2 seconds later I found a YouTube video with a nice gentleman doing a kooks install.
http://youtu.be/ASLpy00BZrw
Old 05-30-2013, 06:27 AM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Search, I found one on you tube as well.
Either job is fairly easy.
Old 05-30-2013, 07:19 AM   #8
CamaroBlue
CamaroBlue's Avatar
I know that's your thing to tell people to search but you're really not helping by being a jerk.
Old 05-30-2013, 07:22 AM   #9
CamaroBlue
CamaroBlue's Avatar
Thanks for the links but to be fair they are all titled header installs. I was searching for exhaust installs. Yes I know they are linked within the instructions but I wasn't searching for headers
Old 05-30-2013, 07:41 AM   #10
Warpaint69
Drives: 2013 VR 2SS RS
Try this video.
Warpaint69 is offline   Reply With Quote
Old 05-30-2013, 07:46 AM   #11
CamaroBlue
CamaroBlue's Avatar
Thanks for the help everyone. Just wanted to make sure I wasn't getting into something over my head but it seems fairly straightforward
Old 05-30-2013, 08:53 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Litle isn't being a jerk at all. You said you searched the forum up and down and he was able to find two sources in less than a minute. Camaro5 isn't the ONLY source of information out there. There are multiple Camaro sites and even more places to find information with a simple Google search. I guess you missed the DIY on exhaust removal in the Camaro5 DIY section, aptly named "exhaust removal". That one took me 5 seconds to find.
http://www.camaro5.com/forums/showth...xhaust+removal
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-30-2013, 09:14 AM   #13
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
Spray a soapy water mix on the rubber hangers. Oil-based products can deteriorate the rubber.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 05-30-2013, 09:49 AM   #14
CamaroBlue
CamaroBlue's Avatar
And of course his sidekick. You guys make a great couple. I have found what I was looking for so there's really no need for you to defend him. Have a nice day.
