SDTW Custom Wheels & Tires
Old 05-30-2013, 02:11 AM   #1
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
V8 differential in 2011v6 Camaro
Just wondering if anyone has done the swap? What would I need for the conversion. This is for a manual car.
Vader2011v6 is offline   Reply With Quote
Old 05-30-2013, 02:16 AM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
The v6 manual and ss have the same diff.
Old 05-30-2013, 02:58 AM   #3
Vader2011v6
I heard that the v6 has a smaller rear end. I was told this by mu dealer.Is that confirmed?
Old 05-30-2013, 05:32 AM   #4
RS111341
RS111341's Avatar
Drives: 2010 2LT/RS
V6 auto has the wimpy diff....I swapped mine in the driveway, nothing to it it's just a matter of swapping parts. You'll need the V8 back half of the drive shaft, half shafts(axles) and hubs(bearings) and the center section of course, if you had a a6.....since you have a m6 you have the bigger diff already.
RS111341 is offline   Reply With Quote
Old 05-30-2013, 07:26 AM   #5
lscamaro
lscamaro's Avatar
The v6 auto has the smaller diff. The v6 manual is the exact same as the v8 one
Old 05-30-2013, 10:18 AM   #6
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
The V6 manual pumpkin is the same. Gear in V6 manual & V8 auto is 3.27, but V8 manual is 3.45. No point in swapping if the V8 rear is from V8 auto, but you would get different gear ratio if swapping to V8 manual.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 05-30-2013, 04:09 PM   #7
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
I hope that same dealer will not be doing any work on the car if they don't know about the differential.
etmx183 is offline   Reply With Quote
Old 06-04-2013, 07:29 PM   #8
Vader2011v6
There actually a good dealer. I wasn't talking to the master tech. Thanks for all the info though . Once I get my car running correctly with the new master cylinder I will probly change out the gears to a 3.73
Old 06-06-2013, 11:21 PM   #9
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
I love how they charge an extra $1200 for an automatic trans then swap to the smaller rear end. Are the cost differences between the manual (plus v8 diff) and auto trans really that price?
Then it will cost you $1200 to get the parts to swap a v6 rear to a v8.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 06-07-2013, 07:58 AM   #10
Vader2011v6
I'm not too sure on the autos but I do know that the charge for filling the rear diff is different from auto to manual.it seems like modifying the autos rear end sounds more expensive.
Old 06-07-2013, 10:20 AM   #11
SC2150
Small rear (A6 is less than 1/2 that complete)
Old 06-07-2013, 11:53 AM   #12
Vader2011v6
This is some really good info. Like you said I think the dealer was thinking my car was an auto when I talked to the service person on the phone.in relieved to know the manual diffs are the same. Guess after my master cylinder ill need a new clutch . Thinking of getting the lower arms front and rear sway bars. Anything else to keep everything in the drive train from breaking? I want my car to feel like it can handle all the power. Currently shifting feels slotchy.
