Cold Air Inductions
Old 05-30-2013, 08:04 AM   #1
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
SSBC 8 piston calipers
8 piston calipers that use common corvette pads. Has anyone tried these yet?
http://ssbrakes.com/i-10093797-calip...grade-kit.html
jeremywes is offline   Reply With Quote
Old 05-30-2013, 10:06 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by SSBC website
Massive 8 Piston braking performance now for 15 in. wheels!!
Complete kit includes:
  • 100% USA made 8 Piston Billet Aluminum Calipers
  • Hi-Performance Hawk HPS brake pads
  • Braided Stainless Steel flex hoses
  • All necessary brackets and hardware included
All for the low-low price of $1,014. Braking it down (see what I did there )
- cheapest "good" set of ss brake lines is about $150
- HPS pads are about another $120
So you're getting 8 piston calipers for like $745 -
That and I'm curious to know what they mean by "brackets and hardware" - I have a feeling they're going to be wheel spacers.
Click to view my build thread
Old 05-30-2013, 10:31 AM   #3
SPCBA
Drives: pleather and Chiclets
what about the rotor? and the fact they are that inexpensive is a little scary
SPCBA is offline   Reply With Quote
Old 05-30-2013, 10:40 AM   #4
Synner
Drives: not stock
- Its a universal caliper with a spacer to get the offset right.
- There's no mention of piston design.
- It looks to be a monobloc but there appears to be no engineering analysis done because there's a lot of excess material that could be removed to make it lighter and not reduce strength.
- Thats a lot of caliper for a stock size rotor so you only addressed 1 of 2 weak links. Adding racing brake rotors would help but at that price point I would look at different kits.
Synner is online now   Reply With Quote
Old 05-30-2013, 10:43 AM   #5
The Stig
The Stig's Avatar
It apparently can use the stock rotor
Old 05-30-2013, 10:44 AM   #6
SPCBA
even less comfortable with that. I would pass on it OP one of those things that are too good to be true....the pistons are probably the size of a dime if it can fit our rotor size
Old 05-30-2013, 10:47 AM   #7
Synner
Drives: not stock
It states 30 and 35 mm but not the mix. More doesn't always mean better. Especially when they haven't even mentioned any steps to address heat transfer.
