Old 05-30-2013, 06:14 PM   #1
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Exclamation Help, Need Your Ideas.
Ok, so I put in some electronic exhaust cutouts in the same location as two of my friends.
The difference is, they are running headers and not catts.
I think this is the reason I am having the issue at hand. I am stock until after the catts.
My passanger side is over heating my fuel and brake lines.
See pictures.
The orange line and vacuum line is for my whipple BAP.
I obviously need to fabricate a heat shield before I do some big damage. I tried the heat tape... THat didn't work because the glue just gave away and the tape actually melted by the exhaust temp. You can see a bit of the tape left.
I tried to stick a panel of aluminum there to deflect the heat and the only thing that accomplished was the exhaust melting a hole in the middle of the panel.
Now I assume I will have to go into steel. But before I do, I wanted to post here to get some ideas form the C5 family.
Any advice except "move them" will be much appreciated.
franknbeans is offline   Reply With Quote
Old 05-30-2013, 06:23 PM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
I would push your cut outs back some if (I know it would be a pain) and away from your fuel lines. I generally don't recommend putting them that close to the O2 sensors. When the cut outs are open and you are off throttle you will be getting some false leans and dumping a lot of extra fuel for no reason.
Get more power for your dollar! We have the best prices on the hottest parts and we price match!
JUICEDMOTORSPORTS.COM
224-63-JUICE 224-635-8423
Juiced1 is offline   Reply With Quote
Old 05-30-2013, 06:31 PM   #3
franknbeans
Whipped
Drives: 2010 CAMARO
Ugh.. really didn't want to hear this. I don't have the parts I cut out to weld back in.
I have the magnaflow exhaust with only the single resonator in the middle. I can't imagine the exhaust not would change much from what I have if I move them behind the resonator.
Old 05-31-2013, 12:28 PM   #4
franknbeans
Whipped
Drives: 2010 CAMARO
really, that's the only advice form 5,000 people on the board.. move it.. LOL.. oh well. I do have a couple ideas before I do that.
Old 05-31-2013, 12:31 PM   #5
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
Could you fabricate some sort of hood or shroud to guide the exhaust in a different direction (away from the fuel lines and wires) when the cut outs are open?
JWoj3540 is offline   Reply With Quote
Old 05-31-2013, 12:32 PM   #6
SPCBA
Drives: pleather and Chiclets
Juiced gave you a professional opinion and advice. Get the heat away from the lines and sensor. You probably already knew this by how your first post reads.
Goodluck and post a vid of open exhaust when you finish.
SPCBA is offline   Reply With Quote
Old 06-05-2013, 09:12 PM   #7
franknbeans
Whipped
Drives: 2010 CAMARO
Yeah.. moving not a option. Guess I'll build some heat reflectors.
Old 06-05-2013, 09:24 PM   #8
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Headers.
OR a down tube from the cut out to get the exhaust away from the body/fuel lines/wires.
T.
GO HAWKS!!!!!!!
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 06-05-2013, 09:28 PM   #9
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Maybe you should try some steel sheet with insulation glued to the back of it to cover those lines.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-05-2013, 09:35 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Agreed get some headers and mid pipes and start all over.
Old 06-05-2013, 09:40 PM   #11
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
+1 W/ Litle88
K32 Camaro is offline   Reply With Quote
Old 06-05-2013, 10:02 PM   #12
thahemp
Geek
thahemp's Avatar
Haha. Sounds like you could use a beer OP.
x = ~x
Old 06-05-2013, 10:45 PM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
And a shot!
Old 06-05-2013, 10:51 PM   #14
thahemp
Geek
thahemp's Avatar
And some angeldust!
x = ~x
