Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 05-30-2013, 11:07 PM   #1
Misty
Misty's Avatar
Drives: 11 SGM 2LT/RS
High flow cats pass emissions
Will high flow cats pass an emission tests? The ones I am looking at (Solo) are not CARB certified. I am in WA state but we have the same emission laws as CA.
Misty is offline   Reply With Quote
Old 05-30-2013, 11:31 PM   #2
kobSS
kobSS's Avatar
Drives: 2010 2SS/RS
As far as I've heard, the only ones that will most likely pass are the Kooks Green Cats
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers
"Information is the oxygen of the modern age"
Build Thread
kobSS is offline   Reply With Quote
Old 05-31-2013, 12:27 AM   #3
13FastBlkSS
Drives: 2013 Camaro 2SS/RS M6
I used to have a Magnaflow high flow cat on my old firebird and it passed inspection.. but I believe if there is no CARB sticker it probably won't pass..
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs
Build#24869
13FastBlkSS is offline   Reply With Quote
Old 05-31-2013, 07:19 AM   #4
2010SSRSM6
2010SSRSM6's Avatar
No CARB #, no pass.
Old 05-31-2013, 11:16 AM   #5
RedVborn
SoCal HT5
RedVborn's Avatar
Drives: LS camaro m6
If ur lucky u might get a lazy tech n just stair at ur camaro the hole time he might nt even look for any E.O numbers cuz ima a smog tech and there r techs out there that don't now what there looking at/for most of the time so ask around smog places n see how old these smog techs , younger techs won't now they'll just get ur car in and out
RedVborn is offline   Reply With Quote
Old 05-31-2013, 11:48 AM   #6
SPCBA
Drives: pleather and Chiclets
No aftermarket cats have a carb sticker.
SPCBA is offline   Reply With Quote
Old 05-31-2013, 02:38 PM   #7
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Exactly what everyone said...No Carb #/Sticker, you will not pass!
JT
Team STILLEN is offline   Reply With Quote
Old 06-03-2013, 01:03 AM   #8
jag107
jag107's Avatar
Drives: 2010 2SS/RS IOM M6
I didn't see a CARB sticker on my OEM cats either. How would a smog tech know the difference between a hi flow and OEM setup?
Placed order: 02.25.2010
Took delivery: 04.06.2010
Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links
jag107 is offline   Reply With Quote
Old 06-03-2013, 01:28 AM   #9
caper
Drives: 2010 IOM 2ss/RS
oem cats = 2 per side. HF cats = 1
caper is offline   Reply With Quote
Old 06-03-2013, 10:36 AM   #10
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
I thought as of January there was no more sniffer?... Just an OBD reading.
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 06-03-2013, 10:57 AM   #11
jag107
jag107's Avatar
Right, but how would they know that? Maybe its in a database when they look up the car?
Old 06-03-2013, 02:10 PM   #12
GunnyG
Da WHALE
GunnyG's Avatar
Just read the "new" visual inspection criteria...cats must be in original configuration with the same number as OE unless CARB approved. High-flows = no goes!
Old 06-03-2013, 02:15 PM   #13
JewelSS
Norcal Camaros
JewelSS's Avatar
Drives: 2010 Red Jewel 2SS L99
You should be good for a few years and by then it depends on the place you go but definitely ask around before you go to a random shop. Most shops if busy wont take the time look unless your running Longtubes and no mufflers, to obvious....
Fire Extinguisher, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC underhood, grill & underbody led lighting, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, RJT painted engine bay, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, TSP 2" Headers with full 3" XS Power exhaust, 275's all around, Granatelli Slotted rotors & Hawk HPS pads, ACS Side Rockers, ACS Front splitter, ZL1 Grill, Havoc Rear diffuser, BMR 1.4 Springs, BMR Strut tower brace, BMR F/R Sway Bars, BMR Trailing Arms, Custom Tune by Starkweather Performance
JewelSS is offline   Reply With Quote
Old 06-03-2013, 09:58 PM   #14
jag107
jag107's Avatar
Can you fail with no mufflers? Do mufflers affect the emissions in any way?
